Page 3 of 3
Re: Retrofit "MFSW" for POLO 6C, 2015 [help]
Posted: Mon Mar 04, 2019 7:59 pm
by Lktuning
Trim with out CCS 6C0419685A
Buttons with out CCS 6C0959442
Posted: Mon Mar 04, 2019 8:19 pm
by thomasoeli
Thank you, but how can i remove the Trim? I can not find instructions.
If I order the following steering wheel on Ebay and the airbag cable, I would have all the parts which i need, right?
Wheel
https://www.ebay.de/itm/182524646916
Airbag Wiring 6C0971584A
https://www.ebay.de/itm/VW-CADDY-POLO-J ... 3307954785
Can you confirm it? Or do I need a new/another airbag? I dont think so.
Many thanks.
Posted: Mon Mar 04, 2019 9:17 pm
by thomasoeli
I have ordered the wheel and the airbag wiring now. I hope it works together.
Which coding is needed in VCDS? Only activation for multifunction wheel?
Posted: Sun Mar 17, 2019 5:16 pm
by thomasoeli
Hello @all,
the new steering wheel with the matching airbag cable has arrived.
Is there a guide to removing the steering wheel and the airbag?
Many thanks and best regards,
Thomas
Posted: Fri Mar 29, 2019 5:46 am
by ag69
There are some videos on youtube. They dont mention part number so you have to improvise.
Here is one which seems to be closest :
[youtube]
https://youtu.be/E5LteoUYzKQ[/youtube]
Posted: Fri Mar 29, 2019 6:29 am
by thomasoeli
thank you. You can see the partnumber of my wheel in the attachment. I think this is the right partnumber. Right?
Many thanks for your help.
Thomas
Posted: Sat Apr 03, 2021 6:11 pm
by filipuch
CKarhu wrote: ↑Mon Jan 14, 2019 4:10 pm
After coding with VCDS everything works fine!
I still have the original steering column with cruise control and menu buttons, and the menu buttons on the stalk works as before. And no lost non-compatible functions on the steering wheel.
Tell me what kind of encoding you have done.
