2006 Polo 1.2 Engine Problem
Posted: Fri Jul 20, 2018 12:13 pm
I'm not a regular here but becoming one thanks to my Polo nearing 140k and would sure appreciate your help.
I have started to experience loss of power on motorways travelling around 70mph. Oddly lifting off the accelerator and back on again solves this but I think HP is down.
I have plugged in an ODBII which gave me codes for Cylinder 1 & 2 misfiring, system too lean, have for a while before this had a 'Bank 1 System below threshold' which I have been resetting (naughty I know). So with that, I took out spark plugs (felt a little loose for 2 & 3 and found carbon deposits on the rim (See picture below) which I cleaned, placed back in & put another two coils in.
Problem remains and now get open circuit errors on the cylinder 1 & 2 which is new.
The car generally runs fine, starts up, drives in 30 & 60 zones fine & not stalling; it just occurs at motorway speed and sometime on an incline.
Based on no spark in cylinder 1 & 2 too lean it suggests to me there may be a restriction in fuel indicating Fuel Filter or Fuel Pump. Fuel filter was last changed at 80K but the Pump is not showing typical signs that it is failing. Else, spark plugs?
Your thoughts would be most appreciated.
