UK-POLOS.NET - THE VW Polo Forum • Where is the gearbox foller plug?
Posted: Fri Aug 17, 2018 2:16 pm
by Northstar
Ive googled images and diagrams but can't find the flipping thing!
Is ig on the front of the gearbox? Tried using a mirror too but no luck
Re: Where is the gearbox foller plug?
Posted: Fri Aug 17, 2018 4:01 pm
by alexperkins
Depends on the gearbox. Some of them are above the driveshafts at the back of the gearbox
What engine/gearbox have you got? The codes will be on the label underneath the boot carpet (for example engine codes start A or B and are three letters like BYD, and gearboxes are generally Dxx on wards like DXB, ETG, FHB etc)
Posted: Fri Aug 17, 2018 6:04 pm
by Northstar
Hi alex,
Engine code BBM then JHN
Posted: Fri Aug 17, 2018 6:06 pm
by Northstar
Forgot to say its manual if not indicated i the code
Posted: Sat Aug 18, 2018 12:21 pm
by Northstar
I have found a plug on the back, but it could be the flywheel inspection one
