Immobiliser / ABS problems
Posted: Thu Sep 27, 2018 1:24 pm
I decided to fire up my red GTi a couple of days ago. There were no issues when I first parked her up, one ABS wheel sensor error last time car was started..
Battery had been disconnected but had still gone flat, so hooked up the garage charger (small charge and then boost) and tried to start her up.
ABS light was on, red brake warning light flashing and three long beeps from the console. I have cleared the ABS codes but it keeps coming back with two wheel sensor errors. Is there some functionality that brings on the beep / flashing when more than one sensor has failed ? Do ABS sensors fail so frequently when parked up in a dry garage ?
That's the easy bit. The car started, ran for a couple of seconds and then died. I put the battery on slow charge and returned to the job today. Vagcom scan shows the following.
Next step for me is to swap the battery over to a known good one, but I don't think that is the problem.
I think this is related to a failure of the chip reader coil around the ignition key, but before I start tearing things apart I could do with some confirmation of my diagnosis or further checks to do.
Many thanks
I have two keys, both keys obtain the same results. I have also seen error 18058, but that has not come back after removing / checking fuses on top of the battery.Chassis Type: 6N2 - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01 -------------------------------------------------------
Controller: 036 906 033 A
Component: 1.6l/4V SIMOS3 00HS3148
Coding: 00031
Shop #: WSC 00788
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0110 1101
Address 03 -------------------------------------------------------
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
2 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-00 - -
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
Address 25 -------------------------------------------------------
Controller: 6X0 953 257
Component: IMMO 0003
Coding: 00001
Shop #: WSC 00722
WVWZZZ6NZYY553xyz VWZ1Z0X0252xyz (obfuscated by me)
1 Fault Found:
01176 - Key
07-00 - Signal to Low
End -------------------------------------------------------
Many thanks
