Tyre pressure monitoring system
Posted: Sun Oct 07, 2018 1:47 pm
Looking at getting some allyos with winter tyres for my polo gti. Apparently there is a type monitoring system fitted. Does anyone know if this system operates off typre pressure monitoring valves or if it run off the ABS system. Also what happens if it is TPM valves, will it just beep when i get into the car and i can clear the fault or will it be a constant annoyance?
