White smoke for a bit at idle after 3-4 mins of use?
Posted: Fri Oct 12, 2018 12:55 pm
Hello,
bit of an odd issue thats infrequent but wanted some advise on;
basically if i start the car from cold (say first thing before setting off for work) everything is fine, then sometimes when i get into traffic or some traffic lights within 5 mins of journey and sit idling for for a bit i will occasionally get a fair bit of white smoke out the exhaust for a couple of minutes. when i pull away it clears and doesn't return.
cars performance and running seem to remain unchanged
the oil filler cap has no sign of 'mayo' or any other gunk
the coolant level is remaining the same and seems fine (other than that someones put blue coolant on top of the pink coolant and its slightly over max)
dip stick seems fine, no odd colours or substances - level is fine too although also maybe slightly above max
cars running decat, air filter, forge 007p and a remap if that makes a difference.
