Page 1 of 2
Which lowering springs. Eibach or H&R
Posted: Tue Oct 16, 2018 10:05 pm
by john__m
Eibach or h&r springs on polo gti ?
Which is the better choice ?
Re: Which lowering springs. Eibach or H&R
Posted: Thu Oct 18, 2018 3:19 pm
by Dink
I have eibach springs fitted to my gti and the ride is better than standard (6c gti)
Posted: Thu Oct 18, 2018 7:21 pm
by john__m
Any pics so i can see the height?
H&r do a lower ride height than eibach
Posted: Fri Oct 19, 2018 8:16 pm
by Dink
This is with the eibach springs fitted. It's a subtle drop and is about right imho.
Posted: Fri Oct 19, 2018 10:38 pm
by Andy1273
The rear looks so much better. By how much did it lower by? Did you purchase a standard kit or a specific type for the height?
Any problems with speed bumps, kerbs, pot holes etc....
Posted: Fri Oct 19, 2018 10:45 pm
by Dink
Think eibach only do one drop height for the polo gti and it's around 25mm
I've not had any problems with rubbing or Kerbs.
I didn't want to go to low on the rear as it starts to push the wheel forward and just makes it look broken imho
Posted: Sat Oct 20, 2018 12:30 pm
by john__m
Does look better than standard, and probably not as rough a ride as the h&r ones but i do like the lower look
Posted: Sun Oct 21, 2018 10:33 am
by Andy1273
john__m wrote: Sat Oct 20, 2018 12:30 pm
I agree does look better than standard.
Where may I ask did you get the springs from? VW and how did you get them fitted, independent garage or at VW?
I presume although you've had them fitted to your GTI they will also fit a 6c TSI?
Posted: Sun Oct 21, 2018 11:55 am
by Dink
Andy1273 wrote: Sun Oct 21, 2018 10:33 am
I got them from a site called autodoc.co.uk (they were the cheapest around) and got a local garage to fit them.
You will struggle to get vw to fit them.
There is a part for lowering springs from vw but they can sometimes be a bit of pain to find.
Posted: Sun Oct 21, 2018 1:11 pm
by Andy1273
Dink wrote: Sun Oct 21, 2018 11:55 am
So do you need this part to be able to fit them? You have a part number?
Posted: Sun Oct 21, 2018 3:25 pm
by Dink
No. vw do lowering springs (well they used to) but it's difficult to find the part number. They won't be listed under your vin number
Posted: Sun Oct 21, 2018 8:07 pm
by john__m
You can still get them. They are called vw racingline. But ive heard the ride is terrible and they cost a lot more than eibach or h&rs
Posted: Mon Oct 22, 2018 5:58 pm
by Dink
john__m wrote: Sun Oct 21, 2018 8:07 pm
I'd read up on what the h&r springs are like for ride quality
Posted: Mon Oct 22, 2018 7:32 pm
by Alexnesta
I used Eibach and H&R, with H&R the car was very short and nice but it bounced all the time my car is a 6R Blue GT. After a week of use, Mount Eibach again as the car worked really badly. I bought H&R 35 / 55mm. I sincerely recommend eibach
Eibach:
H&R
Sorry for my english
Posted: Mon Oct 22, 2018 8:34 pm
by john__m
Looks good
