Xenon Bulb Problem!
jackshepherd399
Drives: 2010 Polo 1.4 SE DSG
Xenon Bulb Problem!
Post by jackshepherd399 »
Apologise if someone has already asked this, but ive just fitted some Xenon bulbs and sidelights to my car and they work fine, but now I have the 'Light Out' icon on my dash, ive heard this can happen so would anyone know how I can fix this? ive added the link to the bulbs I bought here: https://www.ebay.co.uk/itm/H7-55w-SUPER ... 2749.l2649
Re: Xenon Bulb Problem!
Hum, I'd say it was the side lights that are causing you issues there!
Edit:- that is very cheap for premium bulbs, so I'm guessing that you will not find even these bulbs are too good, the thing about head light bulbs is/are, they need to be well made and that includes making sure that the build of these bulbs into their mounting bases is done very accurately so that focus and alignment are the same as the original premium Philips bulbs that VW Group tend to fit as standard.
My plan has always to be buy quality uprated bulbs, like Phillips Extremes, if you want to sort out that bulb out issue you will need to either fit some quality side light bulbs from maybe Phillips but the ones with the blue coating that give out a crisp white light - or go the way others have done and buy more expensive LED bulbs that have built in shunt resistors to fool the car's system into thinking that it has the correct filament bulbs fitted.
Bottom line, try again and buy uprated head light bulbs and matching side light bulbs from some where like Powerbulbs as buying cheap can mean buying twice and throwing your money away?
Dink
Drives: 2015 GTI
Post by Dink »
Yeah it will be the led side lights are not can bus compatible.
Just stick your stock lamps back in and it should sort out the problem.
jackshepherd399
Oh right 👍 cheers, if I put the sidelights back in with that not spoil the colour of the new lights?
jackshepherd399
RUM4MO wrote: Sat Oct 27, 2018 2:38 pm Hum, I'd say it was the side lights that are causing you issues there!
Cheers for the advice, I'll certainly look into getting some Phillips side lights instead.
Powerbulbs used to supply a pair of matching side bulbs with the Philips uprated head light bulbs - that worked well.
If you buy Phillips White Vision Ultras from Powerbulbs, that would cost you £22.49 for a pair, just a suggestion.
Edit:- and if they don't give you a pair of free matching side light bulbs you can always place an order with them for the matching White Vision normal filament version of side light bulbs for £8.25 a pair.
jackshepherd399
RUM4MO wrote: Sat Oct 27, 2018 3:15 pm If you buy Phillips White Vision Ultras from Powerbulbs, that would cost you £22.49 for a pair, just a suggestion.
Oh that's not too bad, cheers for that I'll deffo look into them, btw if I change my sidelights back to the stock bulbs, will that still look okay with the xenon lights or do I have to keep them both the same colour I.e change both back to stock
I've edited my posting to include the side light bulbs, but the price I quoted was without the claimed 25% discount that they giving right now.
Edit:- so that makes them £6.19
Sorry the question about changing the side lights back, yes you will notice the difference slightly, but it will be acceptable to plod etc.
jackshepherd399
RUM4MO wrote: Sat Oct 27, 2018 3:21 pm I've edited my posting to include the side light bulbs, but the price I quoted was without the claimed 25% discount that they giving right now.
Excellent! Cheers, bring on payday
jackshepherd399
RUM4MO wrote: Sat Oct 27, 2018 3:23 pm Sorry the question about changing the side lights back, yes you will notice the difference slightly, but it will be acceptable to plod etc.
Great! I knew there would be a difference but I was worried about getting pulled for it, thanks for the advice, much appreciated
Dink
Drives: 2015 GTI
Post by Dink »
If you do change your headlights then I'd recommend the osram nightbreaker laser lamp.
They use 100% xenon gas inside, so will be about the best road legal incandescent lamp you can get.
If you can find any free cash, maybe have a look on ECP, ie Euro Car Parts as they have another of their "special" discount codes.
As long as that works out cheaper than PowerBulbs.
jackshepherd399
RUM4MO wrote: Mon Oct 29, 2018 1:35 pm If you can find any free cash, maybe have a look on ECP, ie Euro Car Parts as they have another of their "special" discount codes.
Oh right cheers! I've already ordered from powerbulbs. It says the Philips headlight bulbs come with free sidelights, but ive ordered some sidelights just in case, as if I get the free sidelights I can use them on my numberplate. Once I've changed the lights that will be it for mods on my SE so I can save for my next car, but at least it will look a little smarter for my upcoming meet.
