2004 belts
Posted: Mon Nov 05, 2018 12:18 am
by Dawn
Hi all.
So today ive been down the motorway. My car sounded fine. Parked up at home. Went back outside afew minutes later and noticed there was a belt of some kind on the floor just near my back wheels. Im not sure if its mine as its on street parking. Does anyone know where the belts are located in my engine please. Its a 2004 manual petrol
Re: 2004 belts
Posted: Mon Nov 05, 2018 9:04 am
by RUM4MO
One quick and easy way to check if it is your auxiliary belt is, put the key in the ignition and switch to the first position, is the charging failure warning light lit, probably a red light? If so then start the engine, is this same light now off, if it is that was not your auxiliary belt.
Sorry I can't remember exactly what the charge failure warning light looks like on that car.
Re: 2004 belts
Posted: Mon Nov 05, 2018 9:45 am
by Dawn
Hi. Thank you for that but i dont think it is. Ive done as you have said and i have no lights on my sreen. I can only see 1 belt going round in my engine. Is that right
Re: 2004 belts
Posted: Mon Nov 05, 2018 2:26 pm
by RUM4MO
Yes that is correct, only one belt.
Re: 2004 belts
Posted: Mon Nov 05, 2018 2:31 pm
by Dawn
Is that the one thats on the drivers side. Pretty big. About 1 to 2 foot long if cut and layed out flat... so that is the only belt in my whole engine.. sorry for all the questions but i haven't a clue. I just found this belt under my car and panicked
Re: 2004 belts
Posted: Mon Nov 05, 2018 3:56 pm
by RUM4MO
Yes that is the crankshaft pulley end of the engine, the other end gets connected to the gearbox. That belt drives the alternator and Air Con compressor via a few relay pulleys and tensioner pulley.
Re: 2004 belts
Posted: Mon Nov 05, 2018 4:18 pm
by Dawn
Right. So apart from that is there any other belts around the engine anywhere
Re: 2004 belts
Posted: Mon Nov 05, 2018 6:16 pm
by RUM4MO
No, no more external belts, if your car has the 1.4 16V petrol engine it has an hidden behind a cover toothed belt, if your car has a 1.2 3 cylinder petrol engine it does a chain enclosed instead of the toothed belt the 1.4 16V engine has.
Re: 2004 belts
Posted: Mon Nov 05, 2018 6:19 pm
by Dawn
Mine is a 1.2 12v... thank you so much for your help
