1.2 tsi service intervals
ma444
Drives: 1.2s 2010
Post by ma444 »
I know the service interval is very 10000 miles or annual but is there a minor and major service program and what additional work would need doing on the major.
Also when does brake fluid need doing, coolant changing and timing chain need changing
Re: 1.2 tsi service intervals
Extra work during the Inspection/Major services varies with the miles/years run - pollen filter every major, ie 2 years, air filter and spark plugs every 6 years or corresponding mileage, ie 60K miles, unless you feel that an air filter change is better done at 4 years.
Brake fluid, after 3 years from new, then every 2 years.
Coolant should be for life if it remains to be the correct VW Spec'd G12+/G12++/G13.
Timing chain would only ever get replaced if it started to get noisy, so not a scheduled service item.
Edit:- sorry if I did not clear up all points, after 12 months/10K miles the car should get an oil change, so it runs minor>major>minor>major year by year or 10K by 10K miles.
