Hello everyone,
I have an vw polo 6C
I tried to active this function bij changing the value from not active to active: Daytime running lights-Tagfahrlicht Aktivierung durch BAP Oder Bedienfolge Moeglich
this has also succeeded only the function didnt work for me. So I tried to return the value from active to not active. Its says Controller accepted the request. Will now read the channel again. When I press OK it keeps showing me the value active instead of not active. [ I think the problem is the china cable so I will go soon to a friend who has an orginal one to check this ]
But the big problem now is when I tried to active this function up here, my cable choose to change also the values of other functions. Thanx to the cable. And how stupid I was, I didnt make an adaptation log.
Now I have this problems:
- DRL is complete off, till I take off handbrake, then the DRL will go on combined with city light and rear light. ( Normally the city light and rear light were off)
- DRL stays on when I change the light to lowbeam ( Normally DRL off)
- Interior lights goes on when I take off the handbrake and goes out when I pull up the handbrake. ( before it worked with lightsensor )
Can someone please check my current adaptation and see what I need to change when I go to my friend. I want everything how it was at first (factory setting)
Thankyou a lot.
https://www.dropbox.com/s/zg7xs0lxzfk44 ... B.pdf?dl=0
VCDS adjustment failed!
zakelijk19
- Drives: Polo 6C
Re: VCDS adjustment failed!
Yeah either set back the value to what it was or go to the dealer and do an online coding/parametrization of 09 (BCM).
zakelijk19
- Drives: Polo 6C
Can you send me an private message if you want. thankyouiichel wrote: Fri Nov 23, 2018 7:30 am Yeah either set back the value to what it was or go to the dealer and do an online coding/parametrization of 09 (BCM).
Why not write on the public forum?zakelijk19 wrote: Thu Nov 29, 2018 11:47 pmCan you send me an private message if you want. thankyouiichel wrote: Fri Nov 23, 2018 7:30 am Yeah either set back the value to what it was or go to the dealer and do an online coding/parametrization of 09 (BCM).
zakelijk19
- Drives: Polo 6C
hahah nevermind, i was wondering if you speak dutch?
Yes I do, it's my mother tongue
zakelijk19
- Drives: Polo 6C
haha i thought so because i saw the same name on an dutch forum.
I speak dutch to so i thought it would be easier for me in dutch, but so far im doing it miraculous well.
Dont know if you can help me with this, i dont know which values i need to change in adaptation.
viewtopic.php?f=56&t=72289
Thanx
