Where are the connecters and wire for boot lamp
Posted: Sat Dec 22, 2018 10:18 pm
by ma444
My boot lamp has stopped working. It's not the bulb, fuse or switch. I took the boot trim off and therr is no sign of leaking etc
Someone has suggested it could be a broken cable where it comes through the boot lid. Which one of the tubes does it come through and how do you get them off.
And someone has said there a connector between the light and the boot. I can't find it. Can someone help
Re: Where are the connecters and wire for boot lamp
Posted: Sat Dec 22, 2018 10:29 pm
by Dink
Isn't the boot light in the the boot so wouldn't go to the boot lid.
I'd be double checking the lamp is fitted correctly (non led one) and making sure the connector is pushed fully home.
Posted: Sat Dec 22, 2018 10:36 pm
by ma444
Yes checked bulb and replaced. Its just that it seems there is a break in the cable between the lamp and the switch in the lid. The wire go from the lamp to the switch in the lid
Posted: Sun Dec 23, 2018 11:41 am
by Dink
You sure the switch is in the lid and not in the latch?
Pretty sure they are in the latch in the boot.
Posted: Sun Dec 23, 2018 11:59 am
by ma444
viewtopic.php?t=52377 tell you where it is!
Posted: Sun Dec 23, 2018 1:05 pm
by Dink
Ahh well I can't I help you then until you have it in bits
