Whining sound coming from the front
Posted: Thu Jan 17, 2019 12:39 am
by wetwop
I noticed a whining sound coming from the front of the car today, only happened in 5th gear over 50ish. It gets more high pitched as the revs increase and only sounds when the accelerator is pressed. Suspect a gearbox bearing but really don't have a clue.
Any suggestions?? Really hoping it's not goosed.
Re: Whining sound coming from the front
Posted: Thu Jan 17, 2019 7:03 am
by dipstr
Yep sounds like the gearbox bearings and possibly 5th gear are worn. Very common as gearboxes are weak. Time for a rebuild
Sent from my SM-G950F using Tapatalk
Posted: Thu Jan 17, 2019 10:17 am
by alexperkins
If it goes when the clutch is down, its more thank likely the gearbox as above
