Page 1 of 2
Please help with this eBay central locking diagram
Posted: Wed Jan 30, 2019 3:35 am
by Orel
Helllo everyone,
I just bought this eBay central looking system and got trouble with the installation.
I connected the 12 V, ground, locking and unlocking signals.
The car gets locked but it’s not unlocking
How I need to connect the unlocking.
Thankss and hope you understand [emoji23]
Oh, and where I need to connect the wire of the windows raise
Re: Please help with this eBay central locking diagram
Posted: Wed Jan 30, 2019 3:37 am
by Orel
Posted: Wed Jan 30, 2019 9:27 am
by alexperkins
Posted: Wed Jan 30, 2019 11:24 am
by Orel
Thank you for this instruction but I’m installed and wired everything. Do you have any clue where Is the unlocking wire? I’m close to finish it and it will be bummer if will need to wait and star over
Thanks Appreciate you work
Posted: Wed Jan 30, 2019 11:25 am
by alexperkins
You can normally pick the wire up from the loom going near the bonnet pull that runs down along the drivers side footwell
Posted: Wed Jan 30, 2019 11:54 am
by Orel
I connect the unlocking pulse to every wire of the locking mechanism (in this diagram) and nothing happens.
Posted: Wed Jan 30, 2019 12:03 pm
by alexperkins
With the resistor as detailed?
Posted: Wed Jan 30, 2019 3:44 pm
by Orel
No, where I need to connect it?
Posted: Wed Jan 30, 2019 3:50 pm
by alexperkins
180 ohm resistor on the open wire in line with the blue/white wire you have already connected the lock wire to
See the last two pages
http://f.shortnd.it/ukp/vw_polo.pdf
Posted: Wed Jan 30, 2019 11:43 pm
by Orel
alexperkins wrote:180 ohm resistor on the open wire in line with the blue/white wire you have already connected the lock wire to
Thanks a lottt will try that.
One last question, I ordered the rcn210 stereo. I need adapter for the antenna wire. Do you know which one I need?
Posted: Wed Jan 30, 2019 11:46 pm
by alexperkins
That looks like an adapter already. Follow the wire back to the loom and see if it’s plugged into something
A photo of the back of the RCN210 will help also
Posted: Wed Jan 30, 2019 11:48 pm
by Orel
alexperkins wrote:That looks like an adapter already. Follow the wire back to the loom and see if it’s plugged into something
Posted: Thu Jan 31, 2019 3:50 pm
by Orel
You saw the photos?
Posted: Thu Jan 31, 2019 3:52 pm
by alexperkins
Depending on the wiring you have now as i couldnt be entirely sure as it still looks like you have an adapter connected, itll either be an ISO to FAKRA or a dual FAKRA to single FAKRA connection. Both available on ebay
Posted: Thu Jan 31, 2019 3:54 pm
by Orel
Do you think this one will fit?
