Windscreen Washer bottle Removal
Posted: Mon Apr 29, 2019 3:58 pm
Hi All,
First post, so please be gentle! I don't own a Polo, but my son does. It's an early 2005 1.2L Twist model and I am getting it spruced up for it's MOT while he is away at University. (So far, I have replaced one of the front grille sections and put a new drivers side wing mirror on).
The first issue I need help with is that the windscreen washer doesn't work. If I put water into the washer bottle spout it all dribbles out on the floor under the front wing. So I am assuming the washer bottle is shot - he banged the car up a little at the front, is I wouldn't be surprised if the bottle is cracked or split.
So how do I go about removing it? Does the bumper need to come off - and if so, how do I get that done?
I am pretty mechanically inclined to the point of building motorbike engines and stuff like that, so I shouldn't have an issue, but wanted to ask experienced heads here how to go about this job the easiest way.
On a side note, I know there is also a split in the corrugated tube near the bonnet join, but that was there previously - now the water won't even stay in the bottle long enough to get pumped to that split - so I am probably looking at replacing the bottle and the entire tube assembly.....
