Jay-Jay's Polo 6R 1.2TSI
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Hi everybody,
I think it's time to show my car on this forum as well. :)
Polo 6R HighLine 5 doors M.Y.2010 metal silver
1.2 TSI (CBZB) 105hp/77kw
6 gears manual transmission
    • Image
During the last 6 years I did a lot of modifications to it.
Here is the complete updated list:
Engine:
  • Timing chain kit “B”
  • Custom ECU Remap (133hp/232Nm)
  • Polo 6R GTI intake hose
  • Custom intake convejor guide channel
  • Sprintfilter air filter
  • Resonator delete
  • Polo 6R GTI muffler
  • Black cap for expansion coolant tank
  • Black cap for brake fluid reservoir
Mechanic:
  • Bilstein B14
  • PowerFlex topmounts
  • StrongFlex rear bushings of front wishbones
  • Front. 310mm baffed vented discs (Brembo Max)
  • Rear 272mm solid discs (Zimmermann - from Audi S1 + custom brackets)
  • Complete custom stainless steel braided hoses (front + center + rear till the rear calipers)
  • Front 20mm anti-roll bar (from Polo R WRC)
  • Meyle HD anti-roll bar links
  • Meyle HD inner/outer tie rods
Interior:
  • Scirocco MFSW
  • GTI MFA+ tacho
  • RCD340G
  • MY2014 gear knob
  • MY2014 pedals cover
  • Led interior lights
  • Rear footwell lights
  • Double rear trunk's light
  • Glove compartment's light
  • Leather armrest cover
  • LED lights for sunvisors (from Golf 7)
Exterior:
  • 17" Skoda “Gigaro” rims
  • Bi-Xenon OEM headlights
  • Polo 6C GTI rear bumper
  • Polo 6C GTI sideskirts
  • Led back-up lights
  • Metal-black side mirrors covers
  • Red painted brake calipers
  • Shark antenna
  • Engine bonnet strut
VCDS:
  • Staging
  • Steering wheel assistance (2)
  • Brake booster assistance (2)
  • XDS (1)
  • Automatic closing doors at 15 km/h
  • Automatic opening doors removing the key
  • Speed dependant windscreen wipers
  • Tear wiping
These are only few pictures of all the things I did:
    • Image
I'm not writing all the other works of preventive maintenance I did to it, otherwise this post would be endless [emoji38]
In the end, this is the result of all the passion, love and dedication I put into modyfing and taking care of this car as much as possible.
JDMordicant
Drives: GTI 6c 1.8 TSI DSG 2016
Re: Jay-Jay's Polo 6R 1.2TSI
Post by JDMordicant »
Nice Jay looks like you have worked hard on getting it how you want it.
Do the anti roll bars make much difference?
Jay-Jay
Post by Jay-Jay »
Thank you! :)
Yes, the 20mm front anti-roll bar definetely makes a difference compared to the 18mm stock one.
Less rolling and a much more direct steering wheel are the main benefits.
JDMordicant
Thanks mate, will have to look if worth doing on mine as it's already fairly stiff.
Jay-Jay
Post by Jay-Jay »
I've just seen you have a 6C GTI.
You don't need to buy the 20mm rollbar, because your car already has the 20mm rollbar installed from factory. :)
If you want to update further, you can buy the Eibach or H&R 23mm rollbar.
JDMordicant
Thanks Jay good to know. Don't think it needs any more, rides like a gocart already xD
rico
Drives: vw polo 1.2 tsi 90 6r
Post by rico »
Hi jay jay,
I have polo tsi90 bhp model 2016 i am thinking to remap tp 120bhp but i would like to know if this is realible and if the engine can handle this power amount.
Vinay
Nice 6R Jay-Jay. Congrats! 8)
Did I ever mention that I know how to activate the GRA_High function on all 1.2 TSI CBZ A/B/C of VW group? (siemens or bosch)
Jay-Jay
Post by Jay-Jay »
Hey ciclo, thank you so much! [emoji2]
Yes, I followed all your progresses when you were learning how to activate it. I live in Rome and I drive in the city 99% of the time, so I'm not honestly interested in GRA function. But, if I'll ever change my mind, I know who I can ask to! [emoji1]
rico wrote:Hi jay jay,
Vinay
From what I've seen in the past years, your engine can handle a lot more power.
Yours is the 1.2TSI 110hp, underpowered to 90hp from factory.
So, the power increasement is the same of the 110hp version.
Just a good (custom) ECU remap can increase the power to ~140 hp (go check JBS Auto Design YouTube channel and you will see).
The reliability matter depends on many factors.
First of all, how the ECU remap is done (trust well known tuners and avoid "prepacked" remaps! Your engine deserves a custom remap).
Second, the maintenance and the way you drive and take care of the engine (always use good quality engine oil, replace it frequently, never push the engine when cold, let it sit for a while after heavy or highway driving, etc.).
From my experience with the older generation of 1.2TSI engine, I'm extremely happy and satisfied with the remap's results: I will never get back and I suggest everybody to do the same.
I have a friend with the same engine as yours, he remapped 20.000km ago and he thinks the same of me.
Plus to that, with the remap engine gets a nice boost in torque (especially at low revs), which enhances the all-around drivability and allows you to use the gearbox less than before!
Jay-Jay
Post by Jay-Jay »
In the while, I've just upgraded my suspensions from Bilstein B12 to Bilstein B14.
I decided to do it for a comfort reason.
Eibach Pro-Kit springs specific for my engine are not really good.
They can handle a front (static) axle Ioad up to 860kg and my car has a front load of 850kg. So they are at their limit and when driving over potholes, they simply can't handle the front dinamic load.
I once tried the heavier Eibach front springs (front axle load up to 940kg), but the front axle was too high and I wasn't able to lower it.
With the Bilstein B14 kit this problem is fixed, because the included springs are designed for a front static load up to 960kg, which is more than enough to avoid problems under front dinamic load situations. And plus to that, I can lower the front axle to make it a bit lower than the rear axle, as it should be.
Few pictures of the work I did by myself:
Plus to the comfort increasement, the handling has become a bit better as well. :)
More things to come... stay tuned! [emoji6]
Jay-Jay
Post by Jay-Jay »
Boost gauge integrated in the driver's side air vent grill.
Jay-Jay
Post by Jay-Jay »
A new video of the acceleration sound (with some pops and crackles).
When ASR activates (loosing traction), the exhaust produces a very loud crackle: unfortunately there was too much traffic when recording yesterday and I've not been able to make it do it.
Sounds good on my audio equipment, but I have no experience in these matters.
Jay-Jay
Post by Jay-Jay »
Thank you, Ciclo! [emoji2]
Pierlu
Drives: Polo MY2015 1.2 TSI
Post by Pierlu »
Sounds really good for a stock muffler
