Location of crankshaft sensor on polo se auto 2003
Posted: Sat Jul 06, 2019 11:04 pm
by Sofi1
Hi everyone.
I hope I have posted on the right forum.
I hope someone can help me. My polo has a problem with starting when it’s hot. I’ve been told after a diagnostic that it’s the crankshaft sensor this was after getting the throttle fixed. Went to another garage and they can’t locate the part. He took off the inlet manifold but still no sensor. Anyone have any ideas on how to find or where it is on the polo 2003 auto? Does the starter motor need to come out. If you can help I’d really appreciate it. Thank you sofi. I’ve added pictures of the manifold off.
Re: Location of crankshaft sensor on polo se auto 2003
Posted: Sun Jul 07, 2019 9:13 am
by littlepolo
If you mean the crankshaft sensor and not the camshaft sensor I think it's by the flywheel. If I recall correctly there is a plastic assembly behind the flywheel on the engine block and the actual sensor might be plugged into that, possibly accessible from adjacent the starter motor.
Posted: Fri Jul 12, 2019 1:38 pm
by Sofi1
littlepolo wrote: Sun Jul 07, 2019 9:13 am If you mean the crankshaft sensor and not the camshaft sensor I think it's by the flywheel. If I recall correctly there is a plastic assembly behind the flywheel on the engine block and the actual sensor might be plugged into that, possibly accessible from adjacent the starter motor.
Thank you.
Posted: Fri Jul 12, 2019 7:26 pm
by Sofi1
Got it fixed. A charge of 180 quid!!
Posted: Mon Jul 15, 2019 8:45 am
by littlepolo
Glad you got it fixed. Was that at a VW garage or an independent?
