Problems, Problems.
Posted: Fri Aug 02, 2019 9:35 pm
Hi all,
Could someone please advise whether their car does any of the following. I've had mine about 6 weeks and it's done 680 miles, it's already been to the dealer once because of a "jerky" gearchange between 3rd / 2nd but they said it's normal and a rattly handbrake knob, which they didn't fix. It's booked back in on the 16th for the following:-
Car is a GTI+ bought new in June.
1. Occasional "jerky" gearchange between 3rd / 2nd now also permanent between 4th / 3rd. This makes driving really difficult if approaching a junction / roundabout as I'm reluctant to accelerate until I know the car has decided what gear it wants to be in. The same jerky change seems to be permanent when manually changing down from 5th / 4th.
2. Occasional clicking noise from under the bonnet when gears are changing down.
3. Light grinding noise from under the bonnet (like a dry bearing) which is quite noticeable when starting from cold but can be heard to one degree or another all of the time, especially when passing between buildings with the windows down.
4. Engine lurches when cold, almost like the mixture is too weak. The car is a pain until it's been driven about a mile, I'm bothered that if it's like this in the summer what will it be like in the winter!
Oh, and one last thing, does anyone know how you can tell whether the headlights are on when the switch is in auto, every other car I've had has had a light come on on the instrment panel.
Thanks in advance.
Thanks in advance.
