Anyone have Park Assist and vcds?
Posted: Thu Aug 15, 2019 10:56 pm
by Scotty_boy vw
Guys I’m looking for a favour has anyone got this on there polo as I’m looking to get scans if poss to help out in my next mod quest.
Any help would be massively appreciated
Scott
Re: Anyone have Park Assist and vcds?
Posted: Fri Aug 16, 2019 5:23 pm
by RUM4MO
Is your car a 6C as in your profile, or the current version?
If it is the previous 6C version, then you should have posted in the other section, I have VCDS and a 6C Polo with front/rear parking sensors factory fitted.
Posted: Fri Aug 16, 2019 9:34 pm
by Scotty_boy vw
Profile updated!!!
This is for my 2018 AW and it’s Park Assist where the car parks itself.
Scott
Posted: Sat Aug 17, 2019 8:45 am
by monkeyhanger
Scotty_boy vw wrote: Fri Aug 16, 2019 9:34 pm
Profile updated!!!
Scott
That will be a total pain to do. Park assist requires additional sensors to the normal front and back sensors. There's an additional one each side in front of the front wheel arch.
It's a total gimmick option anyway. I'd safe yourself the expense.
Posted: Sat Aug 17, 2019 1:24 pm
by silverhairs
If your reversing into a space and the car behind has it's wheels on the kerb, your park assist will want to park in the same position, so it will start trying to climb the kerb, not a good idea for alloys
Posted: Sat Aug 17, 2019 8:38 pm
by johnpolo2
I have it fitted and haven't used it once.
Posted: Wed Dec 02, 2020 2:21 am
by alanlaos
Profile updated!!!
Scott
Can you send the coding of this mod, cause i need it also
Posted: Wed Dec 02, 2020 7:57 am
by iichel
Posted: Thu Dec 03, 2020 4:02 am
by alanlaos
Thank you for your reply.
I have a problem. The ABS module coding of Scotty ir totally different that mine. I dont want to change all... i need the right information.
What bytes and bits must change?
XAGICO tutorials modules are differents.
Any ideas?
by alanlaos
Any ideas?
