Car peaks boost lower... Sometimes.
Posted: Wed Sep 04, 2019 3:21 pm
My 17' 1.0 tsi has recently developed this issue. Normal peak boost is 1.5bar and it gradually drops to 1.3 as the revs increase.
Sometimes though i press the pedal to the floor and the car boosts to 1.0 or 1.3 bar and stays there until redline. I can feel it when it happens and the boost gauge confirms it.
It has a full exhaust, an aftermarket intercooler pipe with aftermarket BOV installed, an air intake kit and a custom tune.
The car was working perfectly with all of the above things installed. Now it has developed this issue. No check engine light or faults in the OBD scanner. Also the problem is very incosistant. It appears once every 15 or so accelerations.
Any ideas as to what can be causing this? If it was a boost leak it wouldn't do it so incosistantly, right?
