Coolant and oil levels
Chat about your 2018+ AW model Polos here!
Simmo
Drives: 1.0 (95bhp) SE
Post by Simmo » Wed Sep 11, 2019 9:17 pm
Just wondering if anybody has had cause to top-up their coolant or oil between services?
I didn't check the coolant level when I collected my car from new but after having done just over 700 miles, the coolant is hovering just above minimum. No leaks are present, or noticeable staining anywhere.
My last car was a petrol 1.8 YFSI Audi A3, which had a serious oil issue where I had top pour a litre into the engine every few hundred miles. I'm hoping that the oil consumption on this new Polo is significantly less.
I'd be interested to hear of your experiences so far?
OomStu_ZA
Drives: 2019 VW Polo Gin&Tonic Induction
Re: Coolant and oil levels
Post by OomStu_ZA » Wed Sep 11, 2019 9:26 pm
My last 6c 1.0L required top-up oil every 7000 - 10000 km's but my current 2019 GTI (on ±9000 km's) seems fine so far. That said I'll double check the coolant level tomorrow.
Drives: 2016 6C Polo GTI 5 door, Blue Silk
Post by SRGTD » Wed Sep 11, 2019 9:30 pm
Quite a few instances reported on golfgtiforum.co.uk and vwroc.com by owners of new Golfs experiencing a drop in coolant level.
The usual cause is air being left in the cooling system when it’s filled at the factory. This air then works its way out of the system over the first few weeks / months of use, and the space occupied by the air is replaced by coolant which results in a drop in coolant level in the expansion tank.
I also had this happen in my previous generation Polo GTI. I topped it up with G13 coolant and the coolant level has been stable ever since.
Ive not read of any excessive oil consumption issues, but will leave owners of the current generation Polo to comment on their experiences.
Simmo
Post by Simmo » Wed Sep 11, 2019 9:38 pm
Hi OomStu_ZA, thanks for replying.
Sounds like a decent amount of mileage between oil top-ups. Would be good to hear if your coolant level is normal.
Simmo
Post by Simmo » Wed Sep 11, 2019 9:47 pm
Hi SRGTD, thanks for replying.
A really interesting post, I hadn't realised that air could be in the system and over a short period of time will work its way out but sounds so plausible now you've mentioned it.
I've got some G13 but I think I'll get a bottle of VW mixing fluid too - cheap enough at just under £5 for 5litres. Distilled water is almost impossible to find locally, Amazon seems to be the obvious choice but yet de-ionised water is easy to buy, although not quite the same).
Dark_cze
Drives: AW GTI with MT
Post by Dark_cze » Thu Sep 12, 2019 4:02 am
My GTI was build in Spain. I have around 20 000km on my GTI and made 2 changes of oil already (at 5 000 and 17 000). No need to top up anything and there was no consumption between changes. :)
Drives: Golf R, Polo GTI+ (pre GPF)
Post by monkeyhanger » Thu Sep 12, 2019 7:16 am
My 2018 GTI+ got its first service in August and hadn't needed an oil top up between 0 and 8500 miles.
Post by RUM4MO » Thu Sep 12, 2019 10:27 am
All these sealed cooling systems have built in self purging, it is achieved by allowing a small quantity of coolant to return to the reservoir - you should notice that there is a small "return" pipe at the top of the reservoir ad the large "make up" pipe at the bottom.
VW mixing fluid, I did not know that dealerships sold that, I'd be very surprised if bulk mixing fluid is anything other than deionised water, using distillation as a method to clean up/purify water is very energy intensive as heating and lowering its pressure will be needed to cause boiling, passing mains water through a deionising unit should be all that is needed and saves a serious amount of energy.
Simmo
Post by Simmo » Thu Sep 12, 2019 10:09 pm
Apologies for being a numpty, but what is a self purging cooling system - what does that do?
Yes, the mixing fluid is either distilled or deionised water (probably the latter) to add to the G13 coolant.
I may have had a bit of air in the system that has resulted in a small drop in the reservoir.
Post by RUM4MO » Thu Sep 12, 2019 10:17 pm
Any air in the system will finally make its way to the highest point in the system and so it will get carried onwards into the reservoir by that small hose - by design.
Simmo
Post by Simmo » Thu Sep 12, 2019 10:55 pm
So, does that mean that when the factory filled up the car with coolant, there might have been air in the system, which over the last 6 weeks (since owning the car) has resulted in the small drop in coolant level?
OomStu_ZA
Post by OomStu_ZA » Fri Sep 13, 2019 3:59 pm
So took my vehicle to VW today to confirm coolant levels as I was unable to confirm if it was filled because of the discolouring of the container/bottle. That said all in order and also bought some ready mix (cement :P) coolant and a litre of oil for spares. As an old Boy Scout our motto was "Be prepared." :)
green justin
Drives: 2019 Polo GTI
Post by green justin » Fri Sep 13, 2019 8:38 pm
I had too top up small amount of coolant. No visible leaks.
Even had the dealer check it out.
Adam_013
Drives: 2018 Polo Beats 1.0 95PS
Post by Adam_013 » Fri Sep 20, 2019 10:26 am
I've had to put just over a litre of oil in mine between pickup and first service.
Next service due in 500 miles and only down to half way on the dipstick.
Sent from my LYA-L29 using Tapatalk
Steve_2019
Drives: VW Polo 2019
Post by Steve_2019 » Fri Sep 20, 2019 12:03 pm
Does the Polo come with a free 1 litre bottle of oil for top ups?
Last new VW i bought few years ago had free bottle in the boot.
For the first few thousand miles suppose you expect to top up the oil and coolant why the Engine is running in.
