Routing cable for bluetooth microphone to mirror
Posted: Fri Oct 18, 2019 9:02 pm
by ma444
I'd like to run a cable from the radio to the drivers mirror for a microphone.
What's the easiest route for it.
Where are the airbags cables as I want to avoid them
Re: Routing cable for bluetooth microphone to mirror
Posted: Sat Oct 19, 2019 12:43 pm
by joe6
I just fitted a dashcam and used this route for the power cable. The route I used was beneath the dash to the drivers side, remove the triangular side panel and light switch to aid access and then route the cable up the A pillar. You can prise the A pillar trim back just enough to get the cable out of sight. Remove the overhead light assembly and use a stiff wire to pull the cable through from the A pillar to above the mirror.
Posted: Sat Oct 19, 2019 10:57 pm
by Franciswat
I would pass behind the instrument cluster.
