Filter change but not oil
Posted: Sat Nov 02, 2019 6:30 pm
by Bikergonebald
I just bought a polo 9n 1.4 petrol and the garage had changed the oil but I spotted today that the filter certainly wasn’t changed. It’s only done a few miles so I was going to change just the filter.
If I remove the filter will I lose any oil?
Kevin
Re: Filter change but not oil
Posted: Sun Nov 03, 2019 11:04 am
by littlepolo
Yes, the filter will have drained down with the engine standing/cold. It should be only a cupful. Put some rags below (on top of the undertray).
Posted: Sun Nov 03, 2019 11:20 pm
by Zeno
Also put a rag on top of the alternator.
If it's the same as a 1.2, the filter is sometimes stuck in the housing. Either leaver out with screwdriver it tap it upside down onto a wooden block.
Given they did not change the filter, makes me wonder what oil they have put in it ?
Posted: Mon Nov 04, 2019 10:17 am
by RUM4MO
Zeno wrote: Sun Nov 03, 2019 11:20 pm
No, the 1.4 16V engines don't have a filter case and insert, only a complete can filter, so they just spin off and on.
I've always found them to be reasonably challenging to replace, especially as I used to insist with making sure the filter paper was soaked completely with fresh oil!
I'd second dropping the oil that is in it and filling it with a known good VW 502 or even 504 spec oil, 5W-40 or 5W-30.
