Hi, I’ve recently installed a Volkswagen discover MIB2 system into my 2012 Polo. Replacing the standard RCD310 radio. I am having trouble getting the data port on the back of the unit to work. I have bought an original usb data port and lead that goes from the back of the headunit and comes out of what was a blank piece of plastic next to the aux port. I was wondering if anyone has had any similar problems getting the data transfer to work, as the headunit has Apple carplay but needs an iPhone to be plugged in via the data port. Any ideas? [emoji53]
Vw Discover MIB2 radio installation
Re: Vw Discover MIB2 radio installation
Code the main unit with vcds, vcp or OBd eleven for USB "full"
- Drives: Volkswagen Polo match edition
How should I plug my main unit into the vcds?Rlinegrey wrote:Code the main unit with vcds, vcp or OBd eleven for USB "full"
- Platinum Member
You plug VCDD/VCP in OBD, and from module list select radio
Lol oops i just saw the date...
