P0117 and then some..(coolant sensor or more?)
Posted: Fri Jan 03, 2020 9:08 am
by chevmat08
:!: So my coolant sensor has started misbehaving, or so I am lead to believe from my google-fu. Just wanted some advice!
yesterday I noticed my engine temp needle wasn't moving and after I restarted the car (15min journey) I get a check-engine light with the p0117 (coolant temp sensor low input iirc). Now I am getting a flashing coil light with the EML, and when engine is warm the sensor reads around 50-55°c but I'm fairly certain it's at-temp by this point.(will be checking when I get home)
Car drives otherwise fine, I am assuming it's the sensor but any advice would be fantastic. Also, just now it flashed the low oil light very briefly(but hasn't come back, fluke?).
Re: P0117 and then some..(coolant sensor or more?)
Posted: Mon Jan 06, 2020 3:53 pm
by chevmat08
RESOLVED
Had the sensor changed, seems to be the cause as it's all tickety boo now!
