1st Gear : post pedal box replacement
Posted: Wed Sep 01, 2004 10:38 pm
by DMWRIGHT
Has anyone else had problems with first gear since the pedal box replacement by VW ?
9 our of ten times when trying to put the car into first either at sub 5 mph or even from stand still it just won't go ?? !!
Posted: Thu Sep 02, 2004 12:39 pm
by Si_GTi
No problems here mate. Had some trouble at the weekend with reverse though, and then the clutch cable snapped! D'oh. All sorted now though. But 1st... OK so far!
Posted: Thu Sep 02, 2004 4:00 pm
by CalvinGTI
hey guys, not sure if ive spoken to you b4.
I had kinda the same thing, i took my GTI back to have its pedal box replaced, and after i drove it away my gearbox was completly fcuked.
Didnt like first gear at all, or reverse for that matter.
The thing is the pedal box 'problem' causes the pressure plate on your clutch do go a bit naff. I ended up buying a new clutch and had it fited by a friend.
i paid with labour £350, where as VW will demand £560, so i wouldnt recommend them doing it !
I feel your pain though mate, i nearly knocked the manager out at my local VW dealers when they said they wernt prepared to take money off for the clutch, seeing as its the pedal box that BLATANTLY caused the problem.
Good luck with yours mate !
Calâ„¢
check out
Posted: Thu Sep 02, 2004 4:28 pm
by morrismen
...the clutch depression (not your own :wink: ). The further the pedal comes up, the more it will depress under foot and engage to allow you to change gear easier. I've adjusted mine right up (see previous thread of mine).
And, make sure the alignment of the gears and gear stick is okay... apparently this is a known issue and needs VW to 'tweek' a few bolts underneath to line everything up again...(see previous other thread)
Wot I don't get though it why you should now have problems since the pedal box fitting... this has nothing to do with the gears or gearbox?!?!
