App-Connect
spotter_sam
Drives: 2017 MK5 Facelift Polo R-Line
App-Connect
Post by spotter_sam » Thu Mar 26, 2020 6:48 pm
I just bought a 2017 MK5 Facelift Polo R-Line, its a truly amazing car, however in the infotainment system on the menu it doesn't have the App-Connect option. I would like to add Apple CarPlay however I need the App-Connect option. I know you have to pay for it but I thought you could buy it online now with the vehicles VIN and then it gives you a code to enter in the App-Connect option.
Any help much appreciated,
Dink
Drives: 2015 GTI
Re: App-Connect
Post by Dink » Thu Mar 26, 2020 7:22 pm
If you don't have the app connect option then unfortunately you don't have the right hardware.
So you need to go down the route of changing the unit and possibly the usb socket and wiring
Robbo770
Drives: Polo SEL 1.4 tdi 2014
Re: App-Connect
Post by Robbo770 » Fri Mar 27, 2020 12:55 pm
You will need a media main unit with Apple CarPlay om it, bit inside the glove box changed out, see this if you have this cable a simple mod will make it work as I have proved it on mine
https://uk-polos.net/viewtopic.php?f=56&t=74547
