Hi guys and gals
got a 1993 mk2f 1.3 single point injection genisis, that I have just done a full re shell on and come across a serious problem, pulled the car out the garage yesterday for the first time in a few month and now my car will tickover for a Minuite or 2 then build its revs up to around 2.5k then cuts out
even if I try to keep it running by playing with the throttle it still splutters and cuts out
it has also started to beep inside the vehicle with the oil preasure light being on solid :/
Car ran perfect before when it was in the other shell and its had everything including loom swapped over :/ I'm gonna check for air leaks today and try a few things but any ideas I'll happily try
Thanks for any help
Sent from my Pixel 3 XL using Tapatalk
