UK-POLOS.NET - THE VW Polo Forum • MIB II forgetting camera?
Posted: Sat Apr 25, 2020 12:19 pm
by JaegerStriker
ive just installed a flip emblem reverse camera and it works perfectly untill the car has been left off for a while and then i need to unplug the main connection block to the MIB II unit in order to get the camera to start working again.
camera still flips up but isnt recognised by the unit, not even an error
any ideas why this is happening
Re: MIB II forgetting camera?
Posted: Sat Apr 25, 2020 5:27 pm
by iichel
I don't know, but some questions:
- Is your MIB II original (like, not retrofit/hacked)?
- Is your coding done all correctly?
Posted: Sat Apr 25, 2020 8:19 pm
by JaegerStriker
I've changed the unit out to a unit with carplay capability but that was all coded to the car by VW
I've coded it in the infotainment section 5F byte 19 reverse camera enable
I've realised that a soft reset by long pressing the power button makes it start working again
Sent from my SM-G975F using Tapatalk
Posted: Tue Apr 28, 2020 8:51 am
by Slider09
JaegerStriker wrote:I've changed the unit out to a unit with carplay capability but that was all coded to the car by VW
Not sure if it’s different to the Golf (maybe because I have rear parking sensors). But when I retrofit then camera to my Golf I had to code two modules; infotainment module and park assist.
Do you have rear parking sensors?
Posted: Tue Apr 28, 2020 9:26 am
by JaegerStriker
Slider09 wrote: Tue Apr 28, 2020 8:51 am
i dont have parking sensors. ive thought that this might be the problem. its just odd that it doesnt fix itself with a factory reset but it does with a soft reset
Posted: Thu Apr 30, 2020 10:12 am
by JaegerStriker
UPDATE!
I think its on some kind of 12 hour timer. no idea why
I soft reset last night 9.20pm (i was bored) whilst checking the coding and it still worked at 9am this morning when i parked up at a store. however returning to the car after shopping it needed another soft reset
Posted: Thu Apr 30, 2020 10:38 am
by Slider09
JaegerStriker wrote:UPDATE!
May be worth checking your time and date settings. Have you got ‘summer BST’ checked? There is a bug I think where by if this is checked the car forgets stuff. If I have this checked it forgets the time and can reset it to pretty much anything.
Uncheck BST and set the clock manually.
Posted: Thu Apr 30, 2020 10:44 am
by JaegerStriker
Slider09 wrote: Thu Apr 30, 2020 10:38 am
thanks for the suggestion
i dont have that option checked. i might try checking and unchecking it to try bamboozle it. see if that fixes it
Posted: Thu Apr 30, 2020 10:49 am
by Slider09
Good luck, just out of interest where did you buy the reversing camera kit from?
Posted: Thu Apr 30, 2020 10:53 am
by JaegerStriker
Slider09 wrote: Thu Apr 30, 2020 10:49 am Good luck, just out of interest where did you buy the reversing camera kit from?
https://www.aliexpress.com/item/4000041 ... 4c4d63tGt1
i got it from aliexpress following another guy on here doing the same thing (cant get hold of him for help)
Posted: Mon May 25, 2020 5:00 pm
by JaegerStriker
*UPDATE*
it seems that if i unlock the car and wait a few seconds to turn ignition on then the camera doesnt work and needs a reset
if i jump in and turn ingition on straight away then it works
any ideas what might be causing it?
