Supply voltage for central locking - how does it work?
CH12HOM
Drives: 6R Polo Bluemotion
Post by CH12HOM »
Hi All hope your keeping well during these times,
The other day my polo cut out and lost all electrical control except central locking and headlights.
I've fixed the blown fuse now to the bus controller power (I think it's called)
Now the central locking doesn't work, the BCM makes the relay sounds (indicator lights also flash) yet nothing locks!
Ran a scan and this comes up but I have no idea how the central locks are controlled?
Can anyone out there help or experienced a similar error?
Will
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0351
Revision: BU050001 Serial number: 0456 264110433
Coding: 24B02BBF08A10000002009B02C2B0CD05F80612F7E860441A00000000000
Shop #: WSC 124697 483 00190
VCID: 4189F003D889C347E8-8014
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU006101100014986
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU028091100011225
Coding: 48BC30
1 Fault Found:
03396 - Supply voltage terminal 30 for central locking
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 127
Mileage: 276285 km
Time Indication: 0
Date: 2014.09.17
Time: 01:16:42
albob
Drives: BlueGT
Re: Supply voltage for central locking - how does it work?
Post by albob »
Can't help -- but you'd be better asking in this section for the 6R
viewforum.php?f=56
And welcome.....!
I moved your topic.
Please check fuse number 48
CH12HOM
Post by CH12HOM »
Thank you iichel it was a fuse in the end!
