Installing foglights?
Posted: Fri May 15, 2020 2:14 pm
by Lhzbwz
I’m thinking about installing foglights on my polo. Does anyone know if it’s a simple plug-and-play or do I need to change the cables? I guess some programming/activation is needed..
Re: Installing foglights?
Posted: Fri May 15, 2020 2:27 pm
by giannis159
I installed plug and play and no errors. Nighteye h8.
Posted: Sat May 16, 2020 10:41 am
by Lhzbwz
Thanks for the reply! But I want to install foglights on a car that doesn’t have them - not change the bulb to led
Posted: Sat May 16, 2020 1:13 pm
by giannis159
Lhzbwz wrote:Thanks for the reply! But I want to install foglights on a car that doesn’t have them - not change the bulb to led
I think you must change to led..
Posted: Sat May 16, 2020 2:28 pm
by wayne10244
Check if you got the correct loom with plug first! If not it’s going to make it harder for you to fit as your would to wire the fuse box plus activator it.
Posted: Mon May 18, 2020 12:36 pm
by MattHGR
https://www.kufatec.com/en/volkswagen/v ... -aw1-43545
Comes with a coding dongle and connection guide.
Posted: Tue May 19, 2020 9:20 am
by Lhzbwz
Thanks for the reply’s! By the link you sent I guess i have to change the cables as well.. Even though it looks like the same plug? If I don’t order a complete kit..
Posted: Tue May 19, 2020 9:39 am
by MattHGR
Mine already has fogs, but I'm guessing your fog light housing doesn't have any cables going to it ?
Only thing I can think of for needing a cable set.
