Problems with BCM MAX Upgrade
Posted: Wed Jun 03, 2020 11:35 am
Hello my Polo-friends,
I want to replace the original BCM 6Rxxx087 against the 7Exxx090 but i have some problems.
I am working with VCDS.
So far I replaced the two CAN-wires and took over the codes from 6Rxxx087 to 7Exxx090
1st problem:
Failures with clamp 30 from 09-central-electric and a wrong-coding-failure in the 19-gateway. Battery-regulation is disabeld in the List! Where is the problem? Maybe I have to code something by "coding II" in the gateway - here I need a special security-access.
2nd problem:
The Tailgate don't want to open. "Tailgate-lock short-circute to ground". With the 6Rxxx87 BCM the tailgate-lock is working. In my autoscan the failure is missing, I am sorry, I only noticed it later.
3rd problem:
The cornering-light doesen't works with the 7Exxx090.
Can you please help me? Is the T6-BCM brokken or am I stupid?.
Thank you.
1st problem:
2nd problem:
3rd problem:
Thank you.
Freitag,15,Mai,2020,00:10:47:28270
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x86
VCDS Version: DRV 19.6.2.1
Datenstand: 20191020 DS308.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318 KFZ-Kennzeichen: T TEST
Kilometerstand: 153770km Reparaturauftrag:
Fahrzeugtyp: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318 Kilometerstand: 153770km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: nicht angemeldet 0000
61-Batterieregelung -- Status: Fehler 0010
Adresse 01: Motorelektronik (J623-CAYB) Labeldatei:. DRV\03L-906-023-CAY.clb
Teilenummer SW: 03L 906 023 MA HW: 03L 907 425 B
Bauteil: R4 1.6l TDI H33 9978
Revision: --H33--- Seriennummer:
Codierung: 00114036002400080000
Betriebsnr.: WSC 00788 648 00255
ASAM Datensatz: EV_ECM16TDI02103L906023MA 003011
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 71EF91F4A0C774C759-8024
Kein(e) Fehlercode(s) gefunden.
Readiness: 0 0 0 0 0
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP82.clb
Teilenummer SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Bauteil: ESP8.2i front H05 0001
Revision: --------
Codierung: 210228E3417600B6842814E382D900421700
VCID: 071BDF2CB2435A77E7-8052
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: 6R0-907-044.clb
Teilenummer SW: 6R0 907 044 H HW: 6R0 907 044 H
Bauteil: Climatronic H11 0711
Revision: V0000000
VCID: 38796CD08B3DE58F5E-806C
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0736
Revision: B9080001 Seriennummer: 0771 188151302
Codierung: 3CB029BF08A1000001280E006D2B0FD00080412F008E0844200000000000
Betriebsnr.: WSC 36402 001 104857
VCID: 68D9FC909B1DB50F0E-803C
Subsystem 1 - Teilenummer: 1K0 955 559 AH Labeldatei: DRV\1K0-955-559-AG.CLB
Bauteil: RLS 150911 05 54 0403
Codierung: 03302D
Subsystem 2 - Teilenummer SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 008 1621
Seriennummer: KU0KU005091100014001
Codierung: 00BC30
Subsystem 3 - Teilenummer SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 008 1621
Seriennummer: KU0KU006091100011135
Codierung: 08BC30
Subsystem 4 - Teilenummer SW: 5K0 959 542 C HW: 5K0 959 542 C
Bauteil: E221__MFL-TAS H31 0033
Seriennummer: 0410525
Codierung: 820000
2 Fehlercodes gefunden:
01516 - Klemme 30 links
011 - Unterbrechung
Umgebungsbedingungen:
Fehlerstatus: 01101011
Fehlerpriorität: 3
Fehlerhäufigkeit: 4
Verlernzähler: 67
Zeitangabe: 0
00927 - Klemme 30 rechts
011 - Unterbrechung
Fehlerpriorität: 3
Fehlerhäufigkeit: 4
Verlernzähler: 67
Zeitangabe: 0
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\6R0-919-475.clb
Teilenummer SW: 6R0 919 475 C HW: 7E0 919 475
Bauteil: PARKHILFE 4K H11 0013
Revision: -------- Seriennummer: 47301125100288
Codierung: 108001
ASAM Datensatz: EV_VW250ParkiAssis2 S01008
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E757AC8A119DBBF94-806A
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 K HW: 6R0 959 655 K
Bauteil: VW10Airbag01K H09 0020
Revision: -------- Seriennummer: 003GX00VMR8B
Codierung: 00314B
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9D2618EDD1671F38-801E
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3575HRB405F0P3TEG8R6
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3585HRB405F0P3TE9O5.
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 3515RRB405D0N4A8H1IA
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 3525RRB405D0N4A8K0NI
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 6R0 920 861 H HW: 6R0 920 861 H
Bauteil: KOMBI H04 0206
Seriennummer: 00000008724442
Codierung: 140E01
Betriebsnr.: WSC 49271 126 82202
ASAM Datensatz: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01.rod
VCID: 3A7D76D8BD31F79FA8-806E
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7E0-909-901.clb
Teilenummer SW: 7E0 909 901 HW: 7E0 937 090
Bauteil: GW-K-CAN TP20 H80 0736
Revision: B9080001
Codierung: 042000
1 Fehler gefunden:
01044 - Steuergerät falsch codiert
000 - -
Fehlerstatus: 01100000
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 255
Kilometerstand: 153777 km
Zeitangabe: 0
Datum: 2014.10.06
Zeit: 00:03:56
Adresse 25: Wegfahrsperre (J285) Labeldatei:. DRV\5K0-920-xxx-25.clb
Bauteil: IMMO H04 0014
Seriennummer:
ASAM Datensatz: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 B
Bauteil: LenkhilfeTRW V277
Codierung: 11280
VCID: 2F6B578CEA7322370F-807A
Adresse 56: Radio (J503) Labeldatei:. DRV\5M0-035-1xx-56.clb
Teilenummer SW: 6RD 035 187 A HW: 6RD 035 187 A
Bauteil: MIB2-S-R-CN 025 0210
Revision: -----001 Seriennummer: 11185GD2114114
Codierung: 0000040002000A
Betriebsnr.: WSC 00081 790 00127
VCID: 45871524CCCF8867D5-8010
Ende----------------------------(Dauer: 02:19)-----------------------------
