Is there something wrong with my timing chain?
Polobear6r
Drives: Polo
Post by Polobear6r »
I did a VCDS scan on my 1.2 Polo 6R 60Bhp 44KW car. I googled the fault code and it scared me a little because I read somewhere that there could be an issue with the drive chain.
Can some elaborate on this fault code?
Monday,25,May,2020,20:38:45:23303
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: WVWZZZ6RZCY   License Plate:
Gateway Installation List:  6N0 909 901
Wednesday,03,June,2020,16:58:54:23303
www.Ross-Tech.com
                Address 01: Engine       Labels: 03E-906-019-CGP.clb
Control Module Part Number: 03E 906 019 M    HW: 03E 906 019 B
  Component and/or Version: SIMOS11.1     H03 8949
           Software Coding: 00110016000400080000
            Work Shop Code: WSC 00788 648 00255
              ASAM Dataset: EV_ECM12MPI02103E906019M 001007 (VW25)
                       ROD: EV_ECM12MPI02103E906019A.rod
                      VCID: 2E57F709714C42F6A9-807A
1 Fault Found:
10964 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [032] - Incorrect Correlation
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 234849 km
                    Date: 2101.14.19
                    Time: 20:43:32
                    Engine speed: 910.00 /min
                    Normed load value: 25.1 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 49 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 12.695 V
                    Unlearning counter according OBD: 31
                    Time since engine start: 3 s
                    Engine torque: 28.43750 Nm
                    Accelerator pedal travel-Accelerator position: 0.00 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: -1.125 °
Readiness: 0000 0000
Address 01: DTCs cleared
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: WVWZZZ6RZCY034499   Mileage: 235070km-146065miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8949
   Revision: --------    Serial number:
   Shop #: WSC 00788 648 00255
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3217000B6842924EB84DA00401100
   VCID: 071962ADB27633BE4A-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 316DEC7568725D0EB4-8064
   Part No SW: 6R0 937 085 E    HW: 6R0 937 085
   Component: BCM PQ25 M+   H46 0251
   Revision: BB046001    Serial number: 0430 172110015
   Coding: 62B02BBF08A10048002008002D2B0C900040410F60060000200000000000
   VCID: 3D75C045A42AA96E20-8068
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100014122
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU016061100013956
   Coding: 08BC30
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00PVUS.
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9F9B99EDE40ED695-801E
   Serial number: 3575HRB404V0JR9KC0K6
   Serial number: 3585HRB40570ISD6CGHU
   Serial number: 3515RRB40530L9U4H1JK
   Serial number: 3525RRB405D0L2V2C8FL
   Part No SW: 6R0 920 860 G    HW: 6R0 920 860 G
   Component: KOMBI         H03 0505
   Coding: 140200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 387BD15183088C46F3-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 085
   Component: GW-K-CAN TP20 H46 0251
   Revision: BB046001
   Coding: 002200
   VCID: 70EB2971A3F81406FB-8024
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADF3B198D24EED6B5-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F69EA0DEA464BFEA2-807A
End-------------------------(Elapsed Time: 01:57)--------------------------
I had this code before, cleared it and 56KM later it returned.
Re: Is there something wrong with my timing chain?
https://www.gerritspeek.nl/vag-com_dtc-16400.html
Mogelijke oorzaken:
Bedrading en/of aansluitingen van/naar (G40) en/of (G28) defect
Distributieriem een tandje versprongen
Nokkenaspositiesensor (G40) defect
Krukaspositiesensor (G28) defect
