MFSW Coding
Posted: Tue Jun 16, 2020 8:04 pm
by Tex
So i am busy with the conversion of a MFSW retrofit in my 6C, I am getting the new-used BCM installed next week as mine is a Medi line and doesnt have pin 13, so i want to get the buttons on my new wheel working as well as the DSG paddels, i manged to change the Golf wheel for a wheel that doesnt have CC or ACC control, the wheel is from a Troc.
So my question is what do i change in my coding to support the MF buttons and DSG buttons/paddels?
I have attached a ECU scan:
CAN network gateway
Part #: 6C0909901
Coding: 030000047F0A560071000000000000010001010000000000000000000000 (hex)
Component: GW MQB A0
Fault codes:
66565 Manufacturer-specific code
8531970 Quiescent current
Central electronics
Part #: 6C0937087B
Coding: 00001840425300534B844000400703081000590251010000000000000000 (hex)
Component: BCM PQ26 Me4R
Fault codes:
06922 Manufacturer-specific code
09994 Manufacturer-specific code
Airbags
Part #: 6C0959655A
Coding: 88C0C000000000005C0000CA000800000000 (hex)
Component: VW20Airbag01B
[No fault codes]
Instrument cluster
Part #: 6C0920730A
Coding: 0725090821000008000B68000000000000000000 (hex)
Component: KOMBI
[No fault codes]
ABS
Part #: 6C0907379G
Coding: 21DD2885892A33C81115106F0059841491CC88080005CB098F00 (hex)
Component: ESP9.0i
[No fault codes]
Power steering
Part #: 6C1909144M
Coding: 0007 (hex)
Component: EPS_TRW_ALow
[No fault codes]
Heater & air conditioning
Part #: 6C0820045A
Coding: 200000001000100000 (hex)
Component: AC Manuell
Fault codes:
262914 Manufacturer-specific code
590081 Manufacturer-specific code
Transmission
Part #: 0CW300046P
Coding: 0014 (hex)
Component: GSG DQ200-MQB
[No fault codes]
Engine
Part #: 04E906027BB
Coding: 01250012232411080000 (hex)
Component: 1.2l R4 TSI
[No fault codes]
Infotainment system
Part #: 6C0035869B
Coding: 02620000BE00000041110001000000001F0000840000010000 (hex)
Component: MU-E--ER
Fault codes:
00006 Manufacturer-specific code"
Thank you
Re: MFSW Coding
Posted: Tue Jun 16, 2020 8:42 pm
by iichel
Can this device code any subsystems? You need to code the mfsw module but it's not listed
Re: MFSW Coding
Posted: Tue Jun 16, 2020 9:35 pm
by Tex
Thanks for the reply,
Central electronics
Part #: 6C0937087B
cant the long coding in bold be changed, for example changing one of the 0 to a 1 to enable MFSW etc?
Re: MFSW Coding
Posted: Tue Jun 16, 2020 9:48 pm
by iichel
Have a look here: viewtopic.php?f=56&t=74761
Re: MFSW Coding
Posted: Tue Jun 16, 2020 11:13 pm
by Tex
OK, thank you very much
