Polo AW Led bulbs
- Drives: 2018 AW
Polo AW Led bulbs
Anyone know some error free Led bulbs? I've tried some canbus, most of them give dashboard errors. Only one working atm is the H7 in my headlights. H7 highbeam give errors. Rear lights canbus everything gave an error. Seems like the Polo is too sensitive. Or is there an option to change Halogen to Led in VCDS?
- Dazeredo
- Drives: Polo aw1 1.0t 95hp
Re: Polo AW Led bulbs
I've led in the rear turn signals without errors, but I bought the same bulb that other user already tested.
- Drives: 2018 AW
Could u link me up?
I got my led reverse lights from AliExpress
(P21w bulb) no errors on the display
https://a.aliexpress.com/_dYJCQwZ
Edit :-
The indicator lights are PY21W But I never changed those.
Edit :-
You can code the car for led bulbs instead of standard.
Simple Google search will bring up the code needed
- Drives: 2018 AW
Is that possible with a clone cable?
Not sure. Did my adaptations through OBDEleven, but used a VCDS forum to find the options to change.
- Dazeredo
- Drives: 2018 AW
The led is working, no errors and hella bright. Anyone got a link for the H7 high beam lights? Got the normal ones. Tried 2 different Canbus for the highbeam, both barely light up and gives an error
Can anyone suggest which LEDs work without error? Links posted above no longer work.
