Polo AW Led bulbs
Posted: Wed Jul 29, 2020 3:20 am
by blackscell
Anyone know some error free Led bulbs? I've tried some canbus, most of them give dashboard errors. Only one working atm is the H7 in my headlights. H7 highbeam give errors. Rear lights canbus everything gave an error. Seems like the Polo is too sensitive. Or is there an option to change Halogen to Led in VCDS?
Re: Polo AW Led bulbs
Posted: Wed Jul 29, 2020 8:37 am
by Dazeredo
I've led in the rear turn signals without errors, but I bought the same bulb that other user already tested.
Posted: Wed Jul 29, 2020 1:29 pm
by blackscell
Could u link me up?
Posted: Wed Jul 29, 2020 2:36 pm
by Teee
I got my led reverse lights from AliExpress
(P21w bulb) no errors on the display
https://a.aliexpress.com/_dYJCQwZ
Edit :-
The indicator lights are PY21W But I never changed those.
Posted: Wed Jul 29, 2020 2:38 pm
by MattHGR
You can code the car for led bulbs instead of standard.
Simple Google search will bring up the code needed
Posted: Wed Jul 29, 2020 8:39 pm
by blackscell
Is that possible with a clone cable?
Posted: Wed Jul 29, 2020 9:04 pm
by MattHGR
Not sure. Did my adaptations through OBDEleven, but used a VCDS forum to find the options to change.
Posted: Thu Jul 30, 2020 10:04 pm
by Dazeredo
blackscell wrote: Wed Jul 29, 2020 1:29 pm
Could u link me up?
https://www.ebay.com.au/itm/264669415032
It was cheaper when I bought
Posted: Tue Aug 25, 2020 3:26 am
by blackscell
The led is working, no errors and hella bright. Anyone got a link for the H7 high beam lights? Got the normal ones. Tried 2 different Canbus for the highbeam, both barely light up and gives an error
Posted: Tue Mar 12, 2024 7:00 pm
by danx0r
Can anyone suggest which LEDs work without error? Links posted above no longer work.
