center vents removal - help
kfirg
Drives: polo gti
Post by kfirg » Fri Jul 31, 2020 9:24 am
hello
i have polo gti 2013 (6R)
Could anyone give me some advice on how to remove center vents please?
is there any pictures / manual installation ?
thanks .
just remove the panel + 4 screws and pull out the radio ?
https://www.youtube.com/watch?v=fyqaXV2eXwE
Re: center vents removal - help
Post by RUM4MO » Fri Jul 31, 2020 10:23 am
Audi vents have small holes drilled into each frame, and the plan is to use an "L" shaped tool to pull them out - the holes, if VW also provide this method of extraction are located quite far back into the housings.
Post by amer6R » Fri Jul 31, 2020 10:59 am
You have to remove the radio, and remove the plastic bravket that goes over the whole thing because the vent is behind it.
kfirg
Drives: polo gti
Post by kfirg » Fri Jul 31, 2020 11:57 am
in the video he removed the panel (trim) and 4 screwes .
thats all ?
Post by amer6R » Sat Aug 01, 2020 4:49 pm
No!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 » Sat Aug 01, 2020 6:02 pm
HI,
This would be helpful.
https://youtu.be/zwQ7kO_IlfQ
kfirg
Drives: polo gti
Post by kfirg » Sun Aug 02, 2020 6:23 am
It does not look as simple as it seems..
ag69
Post by ag69 » Sun Aug 02, 2020 12:02 pm
Yes.
Well i had removed mine center vents to replace dummy buttons. It was quite work.
Removing trim, screw and radio is not difficult.
I don't recollect but cage is quite hard to move.
