VW T5.1 Caravelle BCM Upgrade
Limalex
Drives: T5GP
Post by Limalex » Sat Aug 01, 2020 12:23 pm
Hello Guys,
I am posting here beause I heard there are some talented members of this forum whose willing to help us T5 owners.
My goal is to retrofit CCS on MFSW
I attempted to swap my old BCM 7H0 937 087 H 0254 H47 to a 7E0 937 090 D 0762 H82.
I followed the guide I find here and it seamed a really easy upgrade, but encountered some issues during the process. I hope I will be able to get some help and guidance how to solve the issue.
First problem was the Remote adaptation.
When I choose the Adaptation option. I got error on Chanel 01 Not Available massage in VCDS
Also a getting various fault codes. Electric windows not working, indicators not working.
I knew about the instrument lighting issue from previous posts, but was not expecting the rest,
Scan with Old BCM
[Saturday,01,August,2020,11:23:36:36108
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH133237 License Plate: AJ62
Mileage: 135260km-84046mi Repair Order: Old BCM
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 56 69 78 0B
VIN: WV2ZZZ7HZCH133237 Mileage: 135260km-84046miles
0D-Slide Door, Left -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
69-Trailer -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JD HW: 03L 907 309 H
Component: R4 v002 EDC X36 8749
Revision: 22X36--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 79883 336 16496
ASAM Dataset: EV_ECM20BTD01103L906022JD 002011
ROD: EV_ECM20BTD01103L906022JB.rod
VCID: 70ACD288AB2E1F06FB-8024
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1795
Revision: 00H05V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3FCE41B4A6F0B07E32-806A
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD09A7089826A49074AA6510
Shop #: WSC 02756 790 49152
VCID: 393A2FACB0D49E4E0C-806C
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
Component: ClimatronicT5 H19 0407
Revision: 00001003
Coding: 0004000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 699ABFEC88F4EECEBC-803C
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0012304120015096
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0254
Revision: BO047001 Serial number: 0429 108120725
Coding: A0B279382E612413932888106C2B8EDD0080410F60844000300003000000
Shop #: WSC 02756 790 12345
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180412 05 54 0403
Coding: 02302E
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Coding: 010000
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 171
Subsystem 7 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000149465
Coding: E30000
2 Faults Found:
03428 - Activation of Left Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 135263 km
Time Indication: 0
Date: 2014.12.23
Time: 00:06:42
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 135263 km
Time Indication: 0
Date: 2014.12.23
Time: 00:06:42
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02756 790 00000
VCID: 302C1288A3AE5F06BB-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 E HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0013
Revision: -------- Serial number: 47461208500166
Coding: 108102
ASAM Dataset: EV_VW75XParkAssis8K A01005
ROD: EV_VW75XParkAssis8K_A01_VN75.rod
VCID: 34241E989FB66326DF-8060
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H07 0013
Revision: -------- Serial number: 003HM002866L
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3620249089CA7136E1-8062
Serial number: 3495ZRB405B0P7HOEHCF
Serial number: 3505ZRB40510P7AOGGM1
Part No SW: 7E0 920 980 E HW: 7E0 920 980 E
Component: KOMBI H04 0306
Coding: 460F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
VCID: 2D120BFC7C9C32EE90-8078
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2404EED8E756F3A64F-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0254
Revision: BO047001
Coding: 042300
VCID: 70ACD288A32E1F06FB-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 250
Mileage: 135263 km
Time Indication: 0
Date: 2014.12.23
Time: 00:06:46
Component: IMMO H04 0306
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A98C0E08DF2E5D6B5-803E
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000509112665
Coding: 0100000101000000
VCID: 322818806DA26D16CD-8066
Address 78: Slide Door, Right Labels: Redir Fail!
End----------(Elapsed Time: 02:25, VBatt start/end: 13.7V/13.6V)-----------
Scan With New BCM:
[Saturday,01,August,2020,11:47:49:36108
www.Ross-Tech.com
Mileage: 135260km-84046mi Repair Order: New BCM
Chassis Type: 7H-VN75 (7E0)
18-Aux. Heat -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Revision: 00H05V01
Coding: 0014
Revision: 00H43001
Revision: 00001003
Coding: 0004000102
Slave 1:
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Date: 2000.00.00
Time: 00:00:00
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 312180165
Shop #: WSC 35110 377 08192
VCID: 2C1406F84F863BE687-8078
Coding: 02302E
Coding: 010000
Coding: E30000
4 Faults Found:
00532 - Supply Voltage B+
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Time Indication: 0
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 3
Reset counter: 3
Time Indication: 0
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 3
Reset counter: 3
Time Indication: 0
04194 - Vehicle Status with Under-Voltage
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
Coding: 108102
Coding: 460F01
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 0000031
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
OFF
Temperature: 28.0°C
Voltage: 11.56 V
Temperature: 77.5°C
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
OFF
Temperature: 28.0°C
Voltage: 11.49 V
Temperature: 77.5°C
00667 - Ambient Temperature Signal
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
OFF
Temperature: 28.0°C
Voltage: 11.49 V
Temperature: 77.5°C
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 042300
VCID: 689CBAE89BFED7C6A3-803C
2 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
00381 - Databus Instrument Cluster
Fault Priority: 2
Fault Frequency: 3
Reset counter: 3
Time Indication: 0
Serial number:
Address 56: Radio
Cannot be reached
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 0 km
Time Indication: 0
End----(Elapsed Time: 02:04, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Drives: 9N3/6R Rline/G7.5/ⵣ Rline'19/T-Cr'21
Re: VW T5.1 Caravelle BCM Upgrade
Post by ciclo » Sun Aug 02, 2020 1:55 am
Hello Limalex,
For the BCM change please read the first steps at the end of this post.
https://www.uk-polos.net/viewtopic.php? ... 30#p573280 (The first thing...)
However I advise you to read the entire thread.
For the CCS in the MFSW there is a Cruise Control Emulator, it is not OEM.
I have it installed. 8)
All the information here: viewtopic.php?f=56&t=58703&start=4725#p564515
Please read the entire page, sometimes the links don't work properly.
To get a CCE you have to speak to Madwarlock.
Limalex
Drives: T5GP
Post by Limalex » Sun Aug 02, 2020 10:59 am
Hi ciclo,
Thank you to jump in and the links with the info.
It look like i stuck at the very beginning. I would need dealer remote matching. I do not have a clue how much they would charge but find out tomorrow.
I will come back to this topic when it sorted.
Do I need to remove the two wires from the instrument cluster and the white connector of the BCM or it meant for the Auto light install only?
I glad there is an emulator so do not have to find some one who able to patch my ECU
Graylscot mentioned on the tread you linked running two wires from the instrument cluster to the BCM when he was upgraded to 090 BCM. Where can I found info regarding the wiring needed?
Post by ciclo » Sun Aug 02, 2020 8:15 pm
I explain to you:
To make the change from BCM High 087 to Max 090 (7E0 937 090 D in your case), the first thing you have to do is install new CAN lines for the instrument cluster, disconnecting and isolating individually the two wires from the current CAN lines on the Instrument Cluster connector (which belong to the powertrain and they are still active for other units).
The change from BCM High to Max does not have to be related to wanting to install automatic lights later.
The image is very clear. Install this wiring in this way.
In your white BCM connector the 54, 57 slots are empty at this time, that is, before installing the new CAN lines.
The new CAN lines for the instrument cluster are two twisted cables (the usual ones used in VW group), in this case with MQS terminals (x4) at both ends. You can make them yourself or ask someone to make them for you.
Apart from that, the configuration of the current electrical wiring of your lights with BCM high 087 is not correct to install the BCM Max 090, an adaptation must be made. Adding and isolating some cables.
The main objective is to get most of the lights to be controlled by the BCM, which is not the case with your current electrical configuration.
Once the electrical configuration is correct, a new BCM coding is necessary.
With patience, please read the thread that graylscott opened and you may see a little more light on it. https://www.uk-polos.net/viewtopic.php? ... 36#p528319
Post by ciclo » Sun Aug 02, 2020 8:38 pm
You don't need the VW dealer at all to match your remotes if you have VCDS.
Please reread my first reply here. (link and there the links to ross-tech)
