Hidden menu on headunit
Posted: Sat Aug 22, 2020 10:20 pm
I came across a video on a media unit from a golf that had a hidden menu when you hold the setup button, on my composition colour there isnt much, and if you keep holding it there is a futher hidden menu, but mine didnt have that...until now.
So Carista the OBD app had a update that allows the service screen to be active, so when i press and hold twice on the setup screen i got taken to the next hidden menu,and it was awesome. there is so many hidden features in there, i normaly code with carista because its easy, but now that i have this hidden menu i actually found out it supports some coding
I thought i needed VCDS for features like windscreen wipers in reverse, auto fold mirrors, auto rain sensor etc, but in this menu they actually have the code and you can actually change some of the code, like change some 0 to 1s, and it has a guide that shows what each byte will do if it changes to 1, there is also a option to enable all features, like driving school mode which i never new this unit could support, then other features that i know dont work but heated wheel, auto heat when entering the car, lane assist configure... the list is really endless, i have the comfort line so i dont have 90% of the options/hardware, but thought i could share for those that are retrofitting and want to activate some of the retrofits more easily through the headunit, im sure it works on the composition media as well.
