UK-POLOS.NET - THE VW Polo Forum • Removal of Composition Media Unit From Glovebox - How?
Posted: Mon Oct 05, 2020 11:54 am
by rbz5416
Anyone have a detailed removal procedure?
Re: Removal of Composition Media Unit From Glovebox - How?
Posted: Mon Oct 05, 2020 2:07 pm
by Dink
I found it easier to leave the glovebox in position an slowly work it out. You will need to feed the wiring in as you work it out.
Posted: Mon Oct 05, 2020 4:22 pm
by marco_polo
I would suggest pulling the unit half way out then removing the glovebox...there is a video on YouTube for this on a 6R.
I found it easier to unclip the loom from the side of the dashboard as otherwise the cables are quite short. They’re just clipped on as you’ll see once glovebox removed.
Posted: Mon Oct 05, 2020 6:00 pm
by Dink
marco_polo wrote: Mon Oct 05, 2020 4:22 pm I would suggest pulling the unit half way out then removing the glovebox...there is a video on YouTube for this on a 6R.
but how do you stop the lid of the glovebox closing as you try to work it out if it's not fixed?
Posted: Tue Oct 06, 2020 9:34 am
by TrebleTA
When I did it, undo the glove box, then unhock the glove box hinges, this will lover the glovebox flap, so u can now usr the radio removing hocks to slide the unit out. Can get about half way out then u can access the cableing, that has like a leaver lock, i was unable to undo the Ariel cables at the time. Was not sure if the uncliped or just slide off. This was on my 2016 polo gti 6c.
Have a look at me old post, i was adding s dash cam and a radio amp.
viewtopic.php?f=56&t=75109&start=45
