RPM needle drop
Posted: Sat Oct 17, 2020 7:07 am
Hello all, hope you are doing okay.
I own a 2004 vw polo 9n and it’s a first hand car. It used to belong to my dad. However this year I noticed that the rpm needle started to drop a bit when coming to a stop and then it jumps back to its usual idle. I remember once it dropped deep down that the engine has started shaking and then it jumped back to its normal idle like nothing happened. (It never stall)
However I cleaned the fuel reservoir with fuel lines and changed the fuel pump with filter. I’ve found one of the injectors has gone bad so I changed it. Changed the lambda sensor the one near the engine. I cleaned the throttle body and the air pressure sensor. I cleaned the air induction kit. (They are all stock. No aftermarket parts) I tested the purge canister valve and it’s working fine.
In conclusion the car is almost brand new now and the performance has became better after all those changes but still I get the rpm needle drop even though it started dropping slightly and very rare after doing a throttle body adaptation with the computer. It felt ok but as I said I still see it sometimes drops slightly than it’s idle. Any help please ?
