VW Polo 6R BCM upgrade and Auto lights retrofit
nirvnv
Drives: VW Polo 6R MY 2011
Re: VW Polo 6R BCM upgrade and Auto lights retrofit (Completed)
Post by nirvnv »
Hello!
After some absent time, I finally began the work for BCM upgrade (7E0937090), Cruise control, RLS, Auto Dimming rearview mirror and Auto lights retrofit
Yesterday I swapd the BCM for the 7E0 version and retrofited the Cruse control system, the diming mirror and the RLS.
The CC, RLS and mirror are all working great.
At this time, the only errors i get are these two on the BCM:
01516 — Terminal 30; Left
011 — Open Circuit
00927 — Terminal 30 (Right)
011 — Open Circuitt error
Tomorrow I will complete the Auto lights retrofit and rewire the fuse box and the BCM for new instalation and these two errors should be off!
I want to thank ciclo one more time for his help and support!
nirvnv
Post by nirvnv »
I am taking notes to make the remaining wiring and connections but I have a doub on three connection points:
Wich pins on the T17 light switch connector should I connect the singned wires with "?"'
these are the only three wires I dont know where to connect on the T17 plug
nirvnv
Post by nirvnv »
Hello to all!
I finally finished all this mods and everithing is working great!
I had some doubts related to some wire connections but I finally figured it out and I was able to get everithing working as it should!
I really, really want to thank ciclo for its precious help!
TheNLFox
Drives: 6r
Post by TheNLFox »
Hey,
I don’t know if this post is still active
But I just did the retro fit and build my own wiring loom and did the coding.
But the auto headlights won’t come on
Leaving home works when it’s dark so the sensor works but with the ignition on the auto function doesn’t work.
Any ideas?
Thankyou!
Scan please
TheNLFox
Drives: 6r
Post by TheNLFox »
I think I found it I didn’t check light assist in the bcm coding so auto lights work now
the only thing that doesn’t work right now is the high beams.
They work in flash mode when you pull the stalk towards you but not in the constantly on mode.
I already saw something on the internet about: Check 09, long coding, Byte 18, Bit 5: "Output high beam active"
I will look for that tomorrow and if that doesn’t solve the problem I will come back to you 😁
TheNLFox
Drives: 6r
Post by TheNLFox »
Here is my full scan I can’t get the high beams to work flash works perfect so I don’t know what’s wrong the coding in byte 18 bit 5 only gives me an yellow light on my dash but doesn’t do anything my car has oem xenon
Monday,04,March,2024,14:23:10:00009
VCDS Version: 23.3.0.0
Data version: 20230228 DS346.1
www.Ross-Tech.com
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 4039
Revision: --H10--- Serial number: CVN: FCE25323
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6ADB77AF8D7FE0C37D-803E
VINID: 9E69EAAAA1A2A95A400442001464FC1B87
Readiness: 0000 0000
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885212400C4841C1469845600400905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2D063BD65D65EB4A-805A
Serial number: 31051304650184
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C63B1-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397998E3B0599B5BC4-806C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 150132891
Coding: 7CB02B3F48A1000001380F916CEB0FD15AC0472F60053040200000030000
Shop #: WSC 124697 483 00190
VCID: 2D51BCB3741137FB58-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300413 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU017051300013202
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU021051300016376
Coding: 18BC30
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0648419
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU024051300010988
Coding: 18BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU027051300013946
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47331313701875
Coding: 108001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E738BFFA177BC63F1-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01R65RW Dataset Number: v00305696R0 0001
Coding: 00314D
VCID: 4A9BD72FEDBF00C35D-801E
Serial number: 3575HRB404V21AM2290X
Serial number: 3585HRB400M50HCCCOCO
Serial number: 3515RRB400A50H0UBPKT
Serial number: 3525RRB400850H0UFOGR
Part No SW: 6R0 920 860 M HW: 6R0 920 860 M
Component: KOMBI H04 0709
Coding: 140E01
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002200
VCID: 70EF65C7A3A31A1333-8024
1 Fault Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 150
Mileage: 211575 km
Time Indication: 0
Date: 2018.07.02
Time: 17:19:14
Component: IMMO H04 0709
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 00788
VCID: 306FA5C7F7235A1373-8064
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: -------------- Dataset Number: 6R0036v____ 0005
Coding: 0112000001000000
VCID: 77FD5EDBCECD4D2BF2-8022
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2S7488891
Coding: 16000400040001
Shop #: WSC 00081 790 00180
VCID: 4683E31FF1A7E4A3B9-8012
4 Faults Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 110
Mileage: 212487 km
Time Indication: 0
Date: 2018.07.19
Time: 09:05:03
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 110
Mileage: 212487 km
Time Indication: 0
Date: 2018.07.19
Time: 09:05:03
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 110
Mileage: 212487 km
Time Indication: 0
Date: 2018.07.19
Time: 09:05:03
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 110
Mileage: 212487 km
Time Indication: 0
Date: 2018.07.19
Time: 09:05:03
End-------------------------(Elapsed Time: 02:52)--------------------------
7CB02B3F48A1000001380F916CEB0FD15AC0672F60053040200000030000
TheNLFox
Drives: 6r
Post by TheNLFox »
Doesn’t work sadly
I see you put bit 5 on but that only gives me a warning light on the dashboard
I previously with the old lightswitch coded cominghome when you pull the highbeam stalk I thought maybe that’s the problem but can’t get in the adaptation for that anymore probably because that lightswitch isn’t there anymore?
TheNLFox
Drives: 6r
Post by TheNLFox »
I found it!!
Had to check byte 23 bit 0 also: alternative voltage supply for highbeam
The only thing that doesn’t work is the homecoming lights if I put the ignition off the lights go of directly
But the high beams where priority
