Upgrading to wiper stalks with trip and OK/RESET buttons.
Posted: Fri Nov 20, 2020 11:38 am
by mirceaculita
Currently I have the basic instrument cluster and no trip or OK/RESET button on my stalks. My instrument cluster only shows the outside temperature, the time, trip and mileage/speed in mph like in the photo bellow.
- Screenshot_56.png (570.97 KiB) Viewed 3346 times
I am not sure about my IC's part number. If it's necessary I will go and check. I know it's last letter is F because I can't enable needle sweep on it.
My question is if I upgrade the stalks will I be able to switch between the screen modes in my instrument cluster? For example have the fuel consumption in real time or the speed or anything else? I was thinking of upgrading to a MFSW, but the stalks are cheaper.
Also would the upgrade be plug and play with some vcds coding or do I need to run new wires to the bcm or something?
Thank you for your time.
Re: Upgrading to wiper stalks with trip and OK/RESET buttons.
Posted: Fri Nov 20, 2020 5:09 pm
by iichel
yes you can
but you need vcds
Posted: Fri Nov 20, 2020 7:50 pm
by mirceaculita
iichel wrote: Fri Nov 20, 2020 5:09 pm
yes you can
but you need vcds
MUSIC TO MY EARS. Thanks for the response.
Posted: Fri Nov 20, 2020 8:29 pm
by iichel
Perhaps you can consider fitting cruise control as well.
Posted: Sat Nov 21, 2020 11:04 am
by mirceaculita
iichel wrote: Fri Nov 20, 2020 8:29 pm
From what I understand fitting cruise control is a bit of a hassle,with wires having to be run into the ECU which has secured bolts or something along those lines.
Right now to be honest I'm more set on installing heated seats. Even thought it may be harder I feel that they are a bit more important to me than cruise control. No doubt, I will eventually get on to adding it
Posted: Tue May 11, 2021 9:39 am
by mirceaculita
Can this newer style of stalks be installed on a standard 6R?
http://imgur.com/gallery/qf4fc3t
Posted: Tue May 11, 2021 10:43 am
by mirceaculita
Never mind, it is not a straight swap.
Posted: Tue May 11, 2021 3:52 pm
by amer6R
I think you will need to change the connector, steering wheel angle sensor, and re pin. But im not 100% sure
Posted: Tue May 11, 2021 4:31 pm
by iichel
there is not a suitable steering angle sender for these stalks, better not do it.
Posted: Tue May 11, 2021 5:02 pm
by mirceaculita
I've already ordered the standard stalks. They were taken off a broken down car. Let's hope they work.
Is there any chance the retrofit can't work? I remember trying to read the average fuel consumption with my friend's vcds. Tried to read some channel (I'm not sure which) and it said channel unavailable.
Posted: Tue May 11, 2021 8:50 pm
by amer6R
It will work
Posted: Thu Jun 10, 2021 12:52 pm
by mirceaculita
UPDATE POST RETROFIT.
So I managed to get everything done. Everything works perfectly. Probably the hardest thing about this retrofit is getting the right wires and getting the plastic housings off of the connectors.
There was one single hiccup. The clips on the bottom of the new stalks didn't match with the ones on the old slip ring. The ones on the stalks was a bit too high and didn't clip into the ones on the ring. It clipped perfectly on a the other spots and it sat pretty fit in there so I left it as is.
95km/h in 5th, it read 2.0l/100km
3.4l/100km at 100km/h.
6.8l/100km at 150 is also pretty nice.
With the OEM arm rest and the newly retrofitted trip computer I'm probably closer to the Comfortline level than the original Trendline.
Posted: Sun Jun 13, 2021 9:58 am
by Damon
mirceaculita wrote: Thu Jun 10, 2021 12:52 pm
How difficult is it to install the stalks?
Posted: Sun Jun 13, 2021 10:28 pm
by mirceaculita
Not hard at all, as I've said, the hardest part is taking the covers off of the connectors and sourcing the right wires. The rest its just some plastic clips and like 4 bolts. Make sure the wires are plugged in the right spots, turn them on with vcds and it's done
