Is this a familiar code and does someone know where the fault is? My guess it is one of the 2 O2 sensors? (I believe in the Netherlands we call them lambdasensor ?)
Or is it the catalytic converter itself?
the autoscan says:
1 Fault Found:
6093 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
But is Bank 1 a fixed position? For example the Oxygen sensor that is mounted on the exhaust manifold? (and bank 2 the sensor after the catalytic converter?)
Is there a way to clean o2 sensors? I see some video's on youtube but do they work?
Friday,11,December,2020,12:19:27:23303
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZ6R(removed for privacy reasons) License Plate:
Mileage: 241790km-150241mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: WVWZZZ6R(removed for privacy reasons) Mileage: 241790km-150241miles
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 8949
Revision: -------- Serial number:
Coding: 00110016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001007
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 2E57F709714C42F4A0-807A
1 Fault Found:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 836.00 /min
Normed load value: 19.2 %
Vehicle speed: 8 km/h
Coolant temperature: 86 °C
Intake air temperature: 20 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.507 V
Test of catalytic converter: measured value-EFF_CAT_DIAG_OBD[1]: 1.140625
Cat. temperature: bank 1: 769.78751 °C
Engine RPM: 827 /min
Air mass: actual value:-MAF: 101.18 mg/stroke
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3217000B6842924EB84DA00401100
VCID: 071962ADB27633BC43-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 316DEC7568725D0CBD-8064
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 035110798
Coding: 7BB02BBF08A10048002008002D2B0C900040410F60060000200000000000
Shop #: WSC 124697 483 00190
VCID: 428FB3B9DDD4D69454-8016
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU014061100014122
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU016061100013956
Coding: 08BC30
Part No SW: 6R0 959 655 K HW: 6R0
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00PVUS.
Coding: 003232
VCID: 4A9F9B99EDE40ED49C-801E
Serial number: 3575HRB404V0JR9KC0K6
Serial number: 3585HRB40570ISD6CGHU
Serial number: 3515RRB40530L9U4H1JK
Serial number: 3525RRB405D0L2V2C8FL
Part No SW: 6R0 920 860 G HW: 6R0 920 860 G
Component: KOMBI H03 0505
Coding: 140200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 387BD15183088C44FA-806C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002200
VCID: 70EB2971A3F81404F2-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADF3B198D24EED4BC-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F69EA0DEA464BFCAB-807A
End-------------------------(Elapsed Time: 02:00)--------------------------
Address 01: Engine Labels: 03E-906-019-CGP.clb
Control Module Part Number: 03E 906 019 M HW: 03E 906 019 B
Component and/or Version: SIMOS11.1 H03 8949
Software Coding: 00110016000400080000
Work Shop Code: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001007 (VW25)
1 Fault Found:
Fault Priority: 2
Fault Frequency: 3
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
