UK-POLOS.NET - THE VW Polo Forum • 1.2 TDI EGR problems
Posted: Mon Jan 11, 2021 11:51 pm
by Vard593
Had an error code p2563, tool to the garage they replaced the egr system, car was then boosting properly no problems, to then after about 6 months the same error code and performance issues...
Any help? Could it be a vaccuum problem or a sensor?
My engine code is CFWA if thats any help
Re: 1.2 TDI EGR problems
Posted: Wed Jan 13, 2021 8:35 am
by amer6R
If you google the eror its not thenegr fault
Posted: Wed Jan 13, 2021 8:40 am
by iichel
If they replaced the EGR for a P2563, then I'd have a good conversation why they did it. It's clearly a turbocharger system fault (not just the TC, but the vacuum system or piping).
So check VGT, vacuum, wiring, N75, sensor on the turbo.
Posted: Mon Feb 01, 2021 8:50 pm
by Vard593
To be fair it sorted the problem for a while must have been a gunked up egr, but also something else, code hasnt reappeared, since changing n75 valve but engine feels sluggish, get some boost at 2000rpm but not as before.
