Is there any way to get 12V from the light switch?
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
As the title says, I was wondering if there is any way to get power from the light switch.
I was looking into buying RGB LEDs for the footwells and found this kit online with 4 rgb strips for each seat and a remote to change colors. This would be plugged into the cigar lighter socket, but I currently use that for my samsung fastcharger.
I thought about getting power from the light switch and only have them powered when the low beam was on, it it was possible...
til3tsio
Drives: Seat Toledo KG
Re: Is there any way to get 12V from the light switch?
Post by til3tsio »
Of course you can,
If you have the big plug light switch , splice the grey/blue wire that goes to T17a/17
and if you have the smal plug on light switch , splice the grey/blue wire that goes to T10s/10.
Check with a multimeter before instalation.
mirceaculita
til3tsio wrote: Sat Feb 13, 2021 7:41 pm Of course you can,
Perfect. Thank you very much.
til3tsio
Post by til3tsio »
mirceaculita wrote: Sat Feb 13, 2021 7:49 pm
:wink:
these are positive wires , connect the ground wire anywhere that suits you.
make proper connections , insulate everything afterwards.
And use a fuse please
mirceaculita
iichel wrote: Sat Feb 13, 2021 9:34 pm And use a fuse please
I'll definitely try and figure out how to use a fuse with this.
