UK-POLOS.NET - THE VW Polo Forum • Caliper Rattle Front
Posted: Sat May 15, 2021 7:39 pm
by craig_fraser
I have searched and have found numerous posts on the topic of caliper rattle. I recently replaced my front brake discs and pads on my polo (2016), I noticed there were no anti-rattle parts on the caliper or on the pads. When going over bumps you can hear the front brakes rattling, going over bumps with the brakes on they're quiet. There is slight play in the caliper on it's mount when applying force with my hand and it makes the same kind of clank so I am assuming it's that. I'm pretty careful so I am confident parts installed are tightly on, but I will be re-checking tomorrow just in case.
Is there an anti-rattle spring I can fit to these to shut them up (there is no obvious mounting for them on the caliper), or do I need to remove the pads and bend up the backing springs on the pads a bit more to shut them up? Any thoughts / suggestions would be welcomed. If I can get a spring I can pop on without removing everything that would be nice!
Vehicle is a 1.2 Match, 2016.
Craig
Re: Caliper Rattle Front
Posted: Sat May 15, 2021 8:07 pm
by amer6R
Rear callipers?
Posted: Sat May 15, 2021 8:30 pm
by craig_fraser
Front callipers…
Posted: Sat May 15, 2021 8:44 pm
by craig_fraser
More information that might be useful, they are not OEM pads, but brembo. Checking against OEM they’re identical so I am not sure it’s a fitment issue, but again any advice would be helpful.
Posted: Sat May 15, 2021 9:41 pm
by amer6R
Since when pads have springs? And how can you rattle the calliper when it under pressure ( meaning you have pressed the brake several times)
Posted: Sat May 15, 2021 10:13 pm
by craig_fraser
They don’t have springs, some do though but not these, I’m referring to the metal clips on the back of the pad used for mounting.
When the vehicle is parked there is a tiny bit of play in both callipers. When driving you’ll hear then rattle over bumps. If I am braking while going over bumps they are silent. I’m trying to get advice on how to troubleshoot / handle the problem.
To be clear braking works normally.
Posted: Sat May 15, 2021 10:45 pm
by SRGTD
I had a similar issue with the front brakes on my previous car when it was new (2016 Polo GTI). Front brakes used to make a clunking noise - usually when braking after reversing. The noise was attributed to free movement of the pads in the calipers. Other GTI owners experienced it too. Can’t say I noticed any brake component-related noises when driving over bumps though.
The clunking noise stopped after a few months of ownership and never re-occurred again.
Posted: Sun May 16, 2021 6:24 am
by craig_fraser
This is definitely only going over bumps, I’m going to check the carrier pins for tightness later to ensure they’re secure. But I’m usually pretty careful with this stuff.
As before I suspect this would easily be fixed by an anti rattle spring but there isn’t one on this calliper.
Posted: Sun May 16, 2021 7:13 am
by amer6R
Those.plates, or in some pads special fabric isnt used for anti rattle, its used for anti squealing. You can add a light coat of ceramic or copper paste to the metal part of the pad that faces toward the piston.
Guide pins should be torqued to 30 nm. You should be really ablr to wiggle the caliper while its in its normal position.
Posted: Sun May 16, 2021 3:49 pm
by RUM4MO
The anti rattle function comes from the rubber bushes that the guide pins/bolts pass through.
I always check that any new or even older pads being put back on are quite a "snug" fit within the calliper carrier - which in your car is part of the hub carrier.
Make sure that the threaded holes in the hub carrier have not stripped out due to bad handling in the past.
I agree that when things have been newly cleaned up, you should be able to wiggle the calliper by grabbing it - it just proves that the guide pins are free to move through the rubber bushes - but these pins should be a slight interference fit in the rubber bushes.
