Lowering Springs GTI 6C
sd17
Drives: 2016 6C GTI
Post by sd17 »
Modification newbie here... looking to subtly lower my 2016 GTI 6C, nothing too extreme just want it to sit better (as it should be stock IMO).
Any advice on which to go for, where to buy them etc welcome. From what I can see H&R and Eibach seem to be the most popular options. I'm leaning towards Eibach.
Are these the right Eibach ones? - https://www.diversionautomotive.com/pro ... eq=uniform
Do I need to get the headlights adjusted as well as wheel balance when they're fitted?
Dink
Drives: 2015 GTI
Re: Lowering Springs GTI 6C
Post by Dink »
i have the eibach springs fitted to my 6c gti and i'd highly recommend them as a subtle drop with adverse affect on the ride.
£200 is overpriced for them
https://www.demon-tweeks.com/uk/eibach- ... 024-02-22/ is a much more reasonable price.
the headlights auto adjust with the sensor on the rear beam
sd17
Drives: 2016 6C GTI
Post by sd17 »
Dink wrote: Tue May 18, 2021 7:44 pm i have the eibach springs fitted to my 6c gti and i'd highly recommend them as a subtle drop with adverse affect on the ride.
Cheers for that. Do you have a photo of how yours sits with the Eibach springs?
Dink
Drives: 2015 GTI
Post by Dink »
this is after them fitted. only drops it small amount but just enough
sd17
Drives: 2016 6C GTI
Post by sd17 »
Dink wrote: Tue May 18, 2021 8:16 pm Image
Looks great, thanks mate
sd17
Drives: 2016 6C GTI
Post by sd17 »
Are these the right ones for the 6C? The rear axle weight says up to 840kg.
Dink
Drives: 2015 GTI
Post by Dink »
sd17 wrote: Mon May 24, 2021 6:54 pm
yeah that is fine they are the same part number as the diversion ones
sd17
Drives: 2016 6C GTI
Post by sd17 »
Comparison pic of stock vs the Eibach springs in case anyone's interested.
https://imgur.com/a/MoYpwso
tjswallow
Drives: Polo GTI 6C
Post by tjswallow »
sd17 wrote: Mon Jun 07, 2021 6:12 pm Comparison pic of stock vs the Eibach springs in case anyone's interested.
Link for these springs and are you using the wheel centering plates?
I doubt anyone uses centering plates.
sd17
Drives: 2016 6C GTI
Post by sd17 »
tjswallow wrote: Tue Jun 29, 2021 4:12 pm
Got them here - https://www.demon-tweeks.com/uk/eibach- ... 024-02-22/
Eibach Pro-Kit Lowering Spring Kit
SKU: EIBE10-85-024-02-22
No wheel centering plate
tjswallow
Drives: Polo GTI 6C
Post by tjswallow »
sd17 wrote: Wed Jun 30, 2021 7:42 am
Cheers for the reply. also wondered if you had spacers and maybe some more photos your suspension setup looks good.
sd17
Drives: 2016 6C GTI
Post by sd17 »
tjswallow wrote: Wed Jun 30, 2021 10:54 am
Thanks, all stock aside from the springs. I’ll send some more photos this evening.
sd17
Drives: 2016 6C GTI
Post by sd17 »
Here’s some more photos, excuse the dirt - https://imgur.com/a/wV4DYmU
mosmadsam
Drives: 6C BlueGT
Post by mosmadsam »
Looking good, perfect daily driving stance! I've just got my Eibach springs delivered this week, can't wait to get them on. What changes have you felt when driving on them, is the ride a bit stiffer?
