Leds in centre dome
Leds in centre dome
Hi guys new on here so apologies I don't have the right terminology..I want to replace the standard dull yellow bulbs in the centre dome with led ones.I've succeeded in prying off both sides and the front of the dome but the rear ie closest to the windscreen is stuck and I don't want to force it.Any help/advice greatly appreciated Car is an 2020 R line 1.0 petrol btw
Re: Leds in centre dome
Ok I managed to get this sorted..you need to pry away one side of the grey/cream cover with a trim tool,then insert the narrow end of the trim tool/small flat blade screwdriver in between the light housing and the surround,lever it to one side gently and the whole light assembly should now drop down allowing you access to the bulbs
