5th gear adjustment
Posted: Wed May 26, 2021 10:02 am
Hi All,
About 3 months ago I adjusted the gearbox linkage cable as getting reverse was iffy. All sorted now and gearbox is a dream except that recently getting 5th gear is a bit hit or miss. No crushing, just trying to get the gear lever in gear.
There are 2 cables, is the 5th gear cable the same as 1,2,3,4? I say that as I don't want to upset the smooth gearchange I have now if I play with the cable to adjust the 5th gear.
If it is the cable, is it too tight or too loose?
Any advice appreciated
Andrew
Andrew
